Metallic Clicking noise and wheel-hopping while turning at low-speed
  1. cococly
    cococly Member
    Nov 29, 2018
    40
    Occupation:
    Aviation
    2018 Rallye Red Honda Civic Type-R
    Any fellow FK8 owners experience this?
    You are turning into a parking spot. at under 5kph/3mph, When you turn the steering wheel , while applying very little throttle, and the front end of the car produces some metallic clicking noise, and you feel that one of the front tires hops/skids around a little bit.
    This happened only while making a very slow turn. Happened mostly when it's cold outside ( 5C/ 40F or under) It doesn't happen when I am going above that speed.
    I have read that it might be due to the LSD? Or is it not normal?
  2. diakonia
    diakonia Senior Member
    Dec 18, 2017
    146
    113
    Occupation:
    Printer / Photographer
    Richmond, VA
    Alan
    Civic Type-R, Accord, CRV
    The same thing happened to me. I had a rock pebble in my beak roter dust shield. The guys at the dealership took my wheel off and got it out for me. Several others on this forum had the same thing happen. Probably happens because of the soft rubber compound tire kicking the pebble in. Hope this helps
  3. destoups
    destoups Senior Member
    May 10, 2018
    170
    84
    Portland
    Des
    Many
    Dunno about the clicking but the skipping is what i would expect from an LSD.
  4. uhhhson
    uhhhson Senior Member
    Feb 19, 2018
    60
    SL,UT
    jordan
    2015 TACOMA, 2015 EVO X, 2018 CIVIC TYPE R
    It’s the dust shield vibrating from a rock
  5. jdv19852010
    jdv19852010 Member
    Sep 22, 2018
    Georgia
    Jesse
    2018 Civic Type R
    Yes, it has happened to me .. Usually when im leaving work on a cold night. Im leaving my parking spot just barely rolling turning the wheel and it sounds like my wheels are hitting something ...
  6. RedGiant217
    RedGiant217 Senior Member
    Jun 16, 2018
    616
    367
    Indiana
    2018 Honda Civic Type R, 2001 Honda Accord
    This one's not a rock...rocks in dust shield would make a scraping sound.
    I've had the same thing as OP. Someone said it's normal for LSD.
  7. WrenchMunky
    WrenchMunky Member
    Jul 5, 2017
    45
    37
    San Antonio
    Cisco
    2017 Honda Civic Type R #1589 PMM
    Same issue for me as well, wondering if it's just the LSD.
  8. OP
    cococly
    cococly Member
    Nov 29, 2018
    40
    Occupation:
    Aviation
    only a handful of FK8 owners have this issue?
    Has anyone send the car back to the dealer to mitigate the problem? BTW, where are the brake rotor dust shield located?
  9. Z06Chris
    Z06Chris Senior Member
    Dec 16, 2018
    504
    469
    Atlanta, GA
    Christopher Yi
    2017 Chevrolet Corvette Z06 | 2019 Honda Civic Type-R | 2019 Lexus UX200
    I could be way off... But on my Z06, some cars get metallic ticking sound when turning at low speeds. Heard it's just an effect of the floating disc brakes.
    Also the wheel "hopping" when turning at low speeds could be due to the Ackerman Effect. It's very pronounced on my car when tires are cold and turning sharply at low speeds.
  10. jmayo1056
    jmayo1056 Senior Member
    Jul 9, 2017
    81
    93
    Salinas CA
    Jeremy
    2017 Civic Type R PMM #1056
    The hopping while it’s cold is the tires. Assuming you’re still on the factory ones. They do not do well in the cold. The window sticker even had a warning that you shouldn’t drive on the factory tires below 50 I think. The tire’s rubber compound will cause the tire to hop.
    cococly thanked this.
