Mechanical Over-rev / Money Shifted
  1. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    1,199
    605
    Illinois
    Marcus
    '18 Civic Type R (RR)
    Yeah, if your tach hit 8k, then you at least partially engaged 2nd, though it may not mean you blipped the throttle (but it would be far more violent if you didn't). Sorry to hear this happened :( Hope the car is all good, maybe a compression test to ease some unknowns?
  2. MstrSHAKE
    MstrSHAKE Senior Member
    Jul 7, 2019
    100
    SFL
    Adrian
    '19 CW CTR
    Haha yes well for sure it didn’t get throttle in 2nd gear. My hope was that I blipped throttle in neutral from missing 4th gear altogether.
    Car runs and feels fine for now. May have to do a compression test to settle the anxiety.
  3. CivilciviC
    CivilciviC Senior Member
    Oct 19, 2019
    225
    101
    Western Canada
    2018 Civic Type R
    Why are you compression testing the engine and assuming it's ok? Your piston rings won't be damaged on an over-rev. This doesn't make any sense to me.
    What more likely happens is you have valve float occur and you burn your valves. This can also lead to valve and piston contact- valves stay open longer than they should and the pistons come into contact. It depends how fast the engine was actually spinning, and for how long it was spinning at that speed.
    If the engine is still running after a misshift, there likely is no issue. The engine can still run if the valves are only mildly damaged- his could result in additional engine noise, less power, worse fuel economy. A totally destroyed valve would likely take the piston out also. You'd know if that happened.
    Either way, a compression test won't tell you much.
    MstrSHAKE thanked this.
  4. MstrSHAKE
    Jul 7, 2019
    100
    SFL
    Adrian
    '19 CW CTR
    Thanks for the reply. But I thought valve float can cause loss of compression. Either way, I think I would of felt it by now I think. I gotta go back to high rpm pulls to see if I feel loss of power. Don’t mine me and my paranoia
  5. Si_chRis
    Si_chRis Senior Member
    Jul 10, 2017
    128
    110
    Connecticut
    2000 Honda Civic Si, 2018 Honda Civic Type R
    I doubt you would get burnt valves in the short duration of a mechnical over rev. Burnt valves tend to develop over time. If anything, the damage would be valve float and P2V contact. If this happens, your valve seats will not be sealing and a compression or leakdown test would tell you a lot and if something major took place in the engine during the mechanical over rev.
  6. TheShadow
    TheShadow Senior Member
    Apr 19, 2018
    170
    194
    Occupation:
    Engineer
    Iowa
    Ben
    2017 FK8 Type R #00561, 2012 Civic Si, 2000 Civic CX Hatchback
    I think his point was that if you did do damage from the over rev (piston to valve contact) you are probably going to notice it without a compression test. Ever tried to drive one of these 4 bangers when one cylinder isn't holding compression? They don't run to well on only 3. Yeah a compression test will tell you that you can't hold compression if you goobered up a valve, but you will feel the engine not running right long before that.
  7. CivilciviC
    Oct 19, 2019
    225
    101
    Western Canada
    2018 Civic Type R
    Yes, I agree. If anything, they might be a bit scorched, but I too would think there is no real damage. A second or two of extreme heat should be ok.
    Hmm and now that you mention it, I was thinking the leak down only checks the piston rings for leaks- but you're right, if a valve was damaged, it would leak compression that way too. It's a lot less common for the valves to be damaged, unless of course, they're over revved, hence why I wasn't even thinking about it that way.
    The few times I've done leak down tests was to see how the rings were. I've never over revved an engine myself, so it never dawned on me :p
  8. CivilciviC
    Oct 19, 2019
    225
    101
    Western Canada
    2018 Civic Type R
    That, and if any bit of that valve breaks off, it'll be making a very nasty mess inside that cylinder. Noise and likely catastrophic failure. Not to mention, as you pointed out, the engine being unbalanced with one piston doing nothing, making everything very obvious.
    Glad to hear OP isn't having those issues. He also guesstimated how high he over revved, which isn't entirely accurate. Truth be told, while Honda limits the rev range to only 7k on the CTR, our engines likely can handle more without much issue. Honda always over designs their engines and it shows- you can beat the life out of them and they continue chugging along. It also comes down to long life reliability and Honda knowing this engine was made to be beat on.
    I haven't checked, but I would assume the stroke length is similar between the K20C and older K20s. If that is the case, the valve springs might end up being the limiting factor on being able to rev higher, but they can be swapped! :p
