1.5T MAPerformance Track Engine Failure On Our 500hp 10th Civic Si
Status
Not open for further replies.
MAPerformance
Cottage Grove, Minnesota
www.maperformance.com
2017 SI Coupe
After our 500hp 10th Gen Civic SI ran an 11.07 pass we continued to push the car until we had a failure.
Our team mate Daelen walks through the engine failure and provides an in-depth look at which engine
components failed and whats in store for the next time we go to the track
Car has a new transmission in it and is ready to go back out to the track
and still try to get that 10 sec pass on a completely stock short block!
Here are some pictures of the carnage!
Gear inside the oil pump broke into pieces we found a small chunk in the oil pan
which we started to investigate further into the engine
Honda Civic 10th gen MAPerformance Track Engine Failure On Our 500hp 10th Civic Si image_2
The oil pump house also cracked as you can see in this picture
Honda Civic 10th gen MAPerformance Track Engine Failure On Our 500hp 10th Civic Si image_4
This little engine just wont give up lol
Honda Civic 10th gen MAPerformance Track Engine Failure On Our 500hp 10th Civic Si image_3
Thanks for watching and please... feel free to subscribe and/or ask any question you might have
Hollywoo0220
RJ
WA
A slightly bent Rod and shattered gear ring...pretty phenominal for pushing that 500hp at the top. Good research for the CivicX owners going for that kind of power I suppose.
Really curious as to what the ECT2 temps are after your passes? 220*-225*F?
Micah
Toms River, NJ
Finding a breaking point is good. Hopefully they can nail down a reliable limit for those owners looking to go FBO upgraded turbo but sticking with the stock block, head, and internals.
herox
'18 Civic Si
Crazy that you guys are able to rev the motor to 9000. Thank you for sharing, I love how involved you guys are with the community.
turbociv910
taylor
wilmington nc
every picture loading for everyone? maybe becuase im at work.
Bent rod is culprit for sure.
Sounds like we need to look at a crank pulleys too.. not that the stock one is engineered for this type of vibration, but thats a pretty excessive failure considering ive ran motors like this, and worse, before with no oil pump failures, just lost power/compression.
MAPerformance
MAPerformance
2017 SI Coupe
I'm going to look into this picture issue and probably fire off an update.
We are leaning towards bent rod... the ONLY reason we don't just jump to that conclusion is that during 40+ passes, we NEVER lost any significant MPH... the lowest we saw was 126MPH versus the highest 130MPH... which... I think we would all anticipate, if a bent rod was the culprit, causing the issue, we would see some hurt engine passes.
IDK... could have all happened in an instant, too, I suppose. Either way, we are back in the mix with another stock bottom end... and another on the way... determined to break records with the stock bottom end AND learn where and what the failure points are for these 1.5t's
jrschultz
Justin
Delafield, WI
2018 Honda Civic Sport Manual
This was a great video to watch. It makes me wonder what the standard (non SI) 1.5t can handle with the known and not known engine differences. It certainly gives me complete peace of mind that my engine can certainly handle the +9 tune just fine.
Hondanickx
Nick
Belgium
I would love to see some sort of test between the SI and base 1.5t block .I wonder how much less hp the base block could handle vs the SI block
MAPerformance
MAPerformance
2017 SI Coupe
You could probably sign me up for an individual component failure test... something to confirm the reports of hardness and material differences between the internals of these engines...it would be very interesting. I will put it on the list of interesting ideas and see if it is something we can factor in the future. My guess is that the internals would still surprise people, in terms of longevity/strength.
Jes_si562
Jesse
Long Beach
2018 civic si. 1990 Honda civic w d16z6 swap (sold) 2019 Honda Civic Hatchback sport(wifes)
What oil grade where you guys running on the stock block ?
Status
