MAPerformance - L15B7 Upgraded Oil Pump on its way!
Status
Not open for further replies.
MAPerformance
Cottage Grove, Minnesota
www.maperformance.com
2017 SI Coupe
Maperformance Civic X - Boundary Oil Pump
When we set out to build our 10th Gen Civic a few years ago we put our sights fairly high, we wanted to have the highest horsepower, and fastest ET of any other cars out there. We knew that with this would come many challenges, and we feel we have done a great job of finding them and sharing them as they happen, hopefully you guys feel the same!
Earlier last year on one of our first track outings of the summer, after about 40 passes that day on the stock motor we encountered a very loud knocking noise. With a few hours left of track rental, we decided that we had enough time to pull the oil pan and see if it was something that was fixable. As we lay on the parking lot, dripping hot oil and sweat, we get the pan off and as we start to look around we begin finding more and more aluminum bits floating in the pan. Our first assumption was that we cracked a piston, as this motor has now seen a few hundred ¼ mile passes, a few hundred hours on the dyno, and many of those making over 40psi of boost and about 550hp. But, as we began to look further we realized that not only were all the pistons in one piece, they looked to be in near perfect condition even!
Now we are looking around more, only to look to the front cover of our L15B7 to realize that the oil pump housing has come apart and these are the pieces we are finding in the pan. Once we found that, we sadly knew that our day was over and we packed up to head home. The next day we had the engine out of the car and began to tear it down. Once apart what we found was an oil pump gear that had split, and cracked into many different pieces thus cracking the housing.
Honda Civic 10th gen MAPerformance - L15B7 Upgraded Oil Pump on its way! 3jh09So4YLTSm-9S3HttSbm_Nt4IuWdna-t-FzzwoCNXIjgqu3AtD-Aws56125aSPCY4u2eiN0vgr41rSxzsMee2gMklMN4m
Honda Civic 10th gen MAPerformance - L15B7 Upgraded Oil Pump on its way! ByybToblSlbr6HgJ8i_C25k22GBoFn87q9_G1P5cwYEj959EOFwTEu2d0y8Z49TgdTJmwXIG3Ykkiyp_eDyhBfv-PsGKY4tM
Luckily, I knew just the people to call. On many modern engines, as you increase the power, and raise the rev limiter you begin to find the weak points. In many cases one of those is the Powdered Steel oil pumps found in most OE applications. Boundary Pump Division is a company that is no stranger to solving these problems, and I knew they would be able to help us sort a solution for the L15! Since 2005 these guys have been one of the top names in the lubrication equipment side of the automotive aftermarket, with solutions for the Ford Coyote V8, Mazda Miata, Nissan VQ, and many other platforms that have been plagued with oil pump gear failures.
What makes the Boundary pump better? Remember earlier when I mentioned the OEM Powdered Metal gears? Here is good write up from Boundary themselves:
“There is no comparison between billet steel used by Boundary and powdered steel used in OEM oil pumps. OEM oil pumps use a "cost efficient technique" called sintering because its cheap and produces tighter tolerances than casting. However powdered steel is even weaker than castings at only about 6000 PSI of strength. Good billet steels like the one that Boundary uses approach 110,000 PSI in yield strength or around 18 times stronger then OEM sintered steel.”
Honda Civic 10th gen MAPerformance - L15B7 Upgraded Oil Pump on its way! zbVzIoq8k7a4EVieEpsKGNp1GORFpChKDep3WRswnMoUnH8OOMpVW1GOa4_t8t-thlsfXAVNMH4k5JMRlttV2oET6VQso85C
With this switch we are much more confident in the capabilities of this pump, and happy to be working with Boundary on this application so we can continue to push further and further!
We currently have a shipment of these inbound and happy to help with any questions you may have! Please call 1-888-MAPERFORMANCE or email [email protected] , Retail pricing will be $299.00 Shipped in the USA!​
kshawn
Matthew
Maine
2017 Civic SI
How difficult is it to swap this out?
NoKz
Speed Limit Tester
'18 Si Coupe (Sold 12/2021)
Mix this with a better baffled oil pan and tracking the Si is starting to look more and more enticing for me. :D
MAPerformance
MAPerformance
2017 SI Coupe
Also working on some options for that! We looked into a full new pan, but the complexity of the pan would make it quite expensive sadly. Trying to keep it attainable for the average consumer we are currently working on a few more budget friendly options! Have any input on that at all?
-Daelen
amirza786
A
Northern California
To bad they don't do an oil pump for the IS350 line! $299 or even double that would be worth it to upgrade to a solid oil pump
MAPerformance
MAPerformance
2017 SI Coupe
Honestly that one is a little hard to answer, as it will vary based on skill set. The front cover and all timing components will come off to install, so it is a fair bit of work, but the actual complexity level is low and only basic hand tools are required.
We can have it apart and back together in about 7 hours moving at a slow pace with plenty of side tracked tasks.
-Daelen
MAPerformance
MAPerformance
2017 SI Coupe
If my motor is ever opened, this would be a must have.
We have actually done them all in car! Just pull the front cover and you can get to it all fairly easy. No need for the motor to come apart!
Chicago
17 civic hb sport
Should make a DIY
David228cx
David
Spain
-Daelen
Any news on the baffle oil pan front?
Austin
Chicago IL
www.wunderladenracing.com
2018 FK7
Our pans are already baffled
This kind of baffle is usually called a windage tray. Its purpose is to protect the oil in the sump from becoming aerated by displaced air from the spinning crankshaft. This works fine for street driving, but is less than desirable for motorsports. Proper oil pan baffles have a series of trap doors to keep the oil located around the oil pump pickup tube. They usually are pretty critical on cars that are used on the track as it plays a big role in preventing oil starvation.
I've looked at the pan a fair bit now. When I have more time later this year we'll be coming out with a proper pan baffle + windage tray combo.
Status
