MAP EVO X Oil Cooler Kit for Honda Civic X 1.5t
  1. MAPerformance
    MAPerformance Senior Member
    Nov 30, 2017
    624
    1,154
    Occupation:
    MAP Brand Specialist
    Cottage Grove, Minnesota
    Miguel
    2017 SI Coupe
    #1 MAPerformance, Mar 19, 2019
    Civic X Oil Cooler Kit - This one is a kit I am extraordinarily proud of. We recognize that many, if not most of these Civic X's are going to end up being road raced or auto crossed rather than being drag raced. We do have a storied background in drag racing, and I think it is natural that we look at cars with a rather singular vision, but it is always important to take feedback from our customers and apply our abilities and passion to create a product that will speak to them. To that end, we have developed a large capacity oil cooler kit for the Honda Civic 1.5t powered platforms that I believe will be the absolute best kit available on the market.
    Where does our kit shine? Well, to start out... there isn't much in the way of options for the platform and the existing offering apply a simple sandwich style adapter to gain the oil passageways access necessary to feed and return from an oil cooler. Why is this a problem? Use of even the simplest and thinnest adapter will cause the oil filter to hang below the front cross member... SIGNIFICANTLY. That means that you cant use your factory undershield and if you hit speed bump or a pot hole, the oil filter is going to take the complete impact.
    Our kit uses an in house designed and absolutely purpose built solution which changed the orientation of the oil filter. Essentially, you bolt the base plate on like any ordinary sandwich plate, but that is just the base, the top portion bolts on to that base place, sealed by o-rings... once fitted, the oil filter is angled away and forward allowing it to clear the undertray AND it is no longer hanging below anything... it is safe. We even added a port for (end user choice) aftermarket oil pressure gauges or oil temp gauges.
    Beyond all that, we also use top a top notch high capacity Setrab oil cooler which in total, adds almost a full quart of oil to your oiling system. This system is also completely compatible with all existing MAP components so you can rest assured that you can complete your dream build and mix and match any components you see fit without worry of one part interfering with another.
    2tone, N0TYPR, JC671 and 3 others thanked this.
  2. kshawn
    kshawn Senior Member
    Apr 23, 2016
    1,790
    1,322
    Occupation:
    Desktop Support Specialist
    Maine
    Matthew
    2017 Civic SI
    Looking forward to the dirty details ;)
    Price
    Temperature comparisons
    0 doubt it'll do the job :thumbsup:
    R.Andre, MAPerformance and givemeadollar thanked this.
  3. JDM_DOHC_SiR
    JDM_DOHC_SiR Uncle Dave
    Apr 17, 2017
    925
    1,057
    Occupation:
    Government
    Chula Vista/ Eastlake
    2012 Acura TL Califonia Edition / 2018 Civic Si Coupe
    This looks Great!!!:love::thumbsup:
    MAPerformance thanked this.
  4. givemeadollar
    givemeadollar Senior Member
    Sep 3, 2018
    245
    155
    Multiverse
    Matt
    2018 Civic Si Coupe
    This.
  5. JC671
    JC671 Youtube: JaySi.671
    Sep 25, 2017
    129
    84
    Occupation:
    Car Enthusiast
    GU
    JC
    '17 Civic SI, '90 GTR, '10 370z, '90 Mr2 Turbo
    How many row setrab core is this?
  6. OP
    MAPerformance
    Nov 30, 2017
    624
    1,154
    Occupation:
    Miguel
    2017 SI Coupe
    This is a 25 Row core we are using.
    -Daelen
    JC671 thanked this.
  7. JC671
    Sep 25, 2017
    129
    84
    Occupation:
    Car Enthusiast
    GU
    JC
    I’ve had a 34row setrab oil cooler kit in my 370z previously and all I can say is it did wonders for my oil temp and oil life. 370z’s were notorious for running hot and burning oil. The oil temp always controlled when the ECU would start pulling timing as the oil temps got hotter thus Lessing how much power you lost as it got hotter or after each pass on the drag strip.
    I’m just sad that KTuner doesn’t currently have a engine oil temp sensor and one doesn’t come stock to monitor this parameter.
    I’m excited about this and am following closely. Great job @MAPerformance and thank you for your continued support to our platform.
  8. OP
    MAPerformance
    Nov 30, 2017
    624
    1,154
    Occupation:
    Miguel
    2017 SI Coupe
    Thank you all for the feed back :) @JC671 Setrab's are simply THE BOMB!, we actually accounted for KTUNER not having that sensor, which is why we included a provision for a temp/pressure sensor on the filter adapter. We have a large variety of gauges as well we keep in house that we can ship with these kits if you choose to monitor these parameters. Would you like to see a drop down perhaps on our site for a the gauge/sensor combo we recommend the most on the listing of this part when we do upload it to our site ? Any feedback is appreciated
    LEO @ MAP
    R.Andre and JC671 thanked this.
  9. JC671
    Sep 25, 2017
    129
    84
    Occupation:
    Car Enthusiast
    GU
    JC
    Yes, please add options for that. Amazing job again @MAPerformance... Let’s get a group by started.
  10. givemeadollar
    Sep 3, 2018
    245
    155
    Multiverse
    Matt
    2018 Civic Si Coupe
    If we are doing another group buy I want to see a cheesy line about outside temps rising and keeping our cars running cold. Also a combo group buy with intercooler / oil cooler would definitely be pretty cool.
    MAPerformance and JC671 thanked this.
  11. Hondanickx
    Hondanickx Senior Member
    Jun 10, 2018
    350
    167
    Belgium
    Nick
    1998 civic hatch , 2018 White civic sedan
    Great work ! But i would have changed the location of the sensor holes .This way the sensors are facing down and are close to The ground.
  12. OP
    MAPerformance
    Nov 30, 2017
    624
    1,154
    Occupation:
    Miguel
    2017 SI Coupe
    DUDE!!!!! Now that you mention it... I have JUST the pitch for you!
    "Global warming is real...because the deals are getting TOO hot to pass up! Come on down to Crazy MAP's Oil Cooler Kit Emporium to get those temps under control. Keep those temps as low as your blood pressure when you see the blow out discount prices. We deliver smiles for miles and you can spend safe and secure in the knowledge that MAP is the place to BEAT the HEAT!"
    BAM
    Remm, R.Andre and givemeadollar thanked this.
  13. OP
    MAPerformance
    Nov 30, 2017
    624
    1,154
    Occupation:
    Miguel
    2017 SI Coupe
    Great points! It should be mentioned that the pictured unit is actually a prototype we were using to determine good locations for sensors... I think we can only get the ONE in there... the lower one, as you mentioned, wouldn't allow us to easily fit the under tray back in so it is deleted... the other two plugs are actually plugs to cover and seal the bolts that bolt the adapter together. Only the upper sensor location will be in the production unit... really, there just isn't much space to work with in that area
    Hondanickx thanked this.
  14. givemeadollar
    Sep 3, 2018
    245
    155
    Multiverse
    Matt
    2018 Civic Si Coupe
    I'm sold.
  15. R.Andre
    R.Andre Senior Member
    Jan 21, 2017
    San Jose, CA
    2016 Honda Civic EX-T
    I'll be waiting for this kit patiently. Hopefully it comes before summer ends. Radiator and this will be perfect for this CA heat.
