Man... this PRL silicon tube seems a little short...
charleswrivers
Charles
Kingsland, GA
Anyone else install one of these and can tell me whether or not they're sizing is... well... super tight? I'm not sure I'm comfortable it placing the amount of tension on the airbox to get the hose clamps tight.
Picture attached w/o just attached to the box w/o tension. Looks about 1/2" too short. I'd be concerned the engine movement would *really* pull bad. PRL, your thoughts?
Honda Civic 10th gen Man... this PRL silicon tube seems a little short... {filename}
Honda Civic 10th gen Man... this PRL silicon tube seems a little short... IMG_20171217_173022659
I installed mine and it is a tiny bit shorter than stock. Looking at your pic, you have the hose all the way over to the right. Center it up on both sides and it should be ok.
Here is the black hose installed in my car:
Honda Civic 10th gen Man... this PRL silicon tube seems a little short... Untitled 2
charleswrivers
charleswrivers
Charles
Kingsland, GA
Well.. I got it on...
However, as it is flush on the engine side, I have to have a lot of tension on the air box. It isn't trued up to the box and the hose isn't flush on the bottom on the connection on the box. To get it to do even that it's pulling on the air box pretty good. I had to bolt the box down. Having the tube boxed up made it impossible to tighten the 4 screws to 'close' the air box.
No matter. I'm finishing my HID install tonight and will probably go back to the stock tube.
FKSE7EN
2017 HatchBack Sport 6MT
Here’s mines, there’s minimal gaps on both ends. It hasn’t moved in the last 4000 miles I’ve drivin it. Just even out the spacing.
Honda Civic 10th gen Man... this PRL silicon tube seems a little short... 3FA65E66-3DE1-4BE8-BEEB-AF32B91B76B2
dscayton03
Devin
North Carolina
2017 Honda Civic Ex Hatchback
Stage 1 intake?
charleswrivers
charleswrivers
Charles
Kingsland, GA
Stage 1 intake?
Yep. The green filter looked decent. The tube looked fine. They should have just made it a smidge longer though. I buttoned up everything after dark as it was just one thing I was doing in the course of finishing my HID install, so no.pics of what I'm talking about. However, I can tell the fitment isn't quite perfect on the bottom of the airbox and it's 'pulling' on the airbox as it's so tight.
17siturb0
U.S North east
2017 civic si sedan, 2006 civic si coupe
You didn’t put it on right that’s why it doesn’t look like it fits.
charleswrivers
charleswrivers
Charles
Kingsland, GA
Of you're talking about how the left hose clamp isn't on... yes, I did that to show how, w/o it on, there was a natural gap based on the length of the tube. Trying to close that gap involved pushing on the airbox. A lot. If I'm missing something, please elaborate.
Did you even read my post above? You needed to center the hose up. There will be a small gap edge to edge but after tightening the clamps it with function fine. The airbox itself is somewhat loose and will move but the hose will stay on fine.
batman900
Oklahoma
2019 Type-R 2020 4Runner 2019 Camry 2011 Accord
I had the same issue with mine and ended up taking it off. Yes you can turn the hose to find the best fit but it still isn't long enough, after getting it buttoned down as good and snug as possible, I find it works gaps on both sides after X many of miles. Disappointed.
Edit: Indeed the gaps may not effect anything but I don't like it, I wanted and expected something that fits %100.
glbg
NJ
2020 Civic Sports Hatchback
I have not installed my Stage 1 kit yet. Hopefully the weather cooperates this weekend.
dscayton03
Devin
North Carolina
Can you hear a difference in turbo noise or any throttle response?
charleswrivers
charleswrivers
Charles
Kingsland, GA
Honestly, I haven't driven it yet. My old lady took it out last night and ranted and raved about how great the HIDs were, but she couldn't tell anything about the noise/feel of the car.
Then again, my wife couldn't tell when a wheel bearing was shot in one of our last vehicles that was her daily a few years back. Damn thing sounded like it was going to kill itself. She and I had to have a talk about living with that one for days on end. So... nothing she ever says about the sound/feel of a car is to be trusted.
I'll report back any differences once I drive it. Even if it gives it's claimed 5-9 hp, this is within the realm of difference a cool to warm (not hot) day can swing it and is <5% of the total power output of the car... so I'm not expecting much. Sound wise, the new filter's pleats are very short compared to the deep, thick paper ones of the OEM one, so I can believe it may make a slight difference. Whatever the difference, I'll report back once I take it for a spin.
charleswrivers
charleswrivers
Charles
Kingsland, GA
I get what you're saying, but gaps shouldn't exist. There needs to be some play in the hose to provide some amount of movement. My airbox is not very loose at all, and with it, it pulls on it hard. I've swapped to silicon hoses one vehicles before and they were not tight like this.
