Hi guys, i'd like to drop a little bit my hatch, as you may know here in Europe the sport hatch has the electronic adaptive suspension, do you know if it's possible to replace the stock springs in these suspensions?
yes you can however you have to be considered that your rear camber angle will increase from 1,25 degrees to abt 2 degrees.you can see mine fyr. https://www.civicx.com/garage/boe921.1873/
I have no problem with springs and really like ground clearance which is provided by pro kit. you will not lose any comfort up to 100-120 km/h almost same as factory setting however after that the car will jump very lightly depending on road surface.
pro kit eibach (winter tires 16") ride is great much better than factory car is stiffer for sure, but stil not to stiff highly recomend
