wendingTuo
- Dec 22, 2015
- 18
- 8
- Orlando, Florida
- 2016 Civic Touring
I've been experiencing a very frustrating issue with my new Touring edition. Basically, about 50% of the time I turn the car on, my audio system pushes loud, static-y pops through my speakers. I've spoken to two different dealership tech guys, and both of them are at a loss as to what may be causing it. My local dealership has requested that I leave the car with them so they can take a more in-depth look at what may be causing the issue, but I figured I'd post here to see if anyone else is experiencing a similar issue.
Once this issue begins, it persists even when the car is turned off and back on. I've tried a factory reset of the head unit, as well as soft resets using the long press of the Audio Power button. This issue occurs regardless of whether bluetooth is connected. It also occurs when the audio is off on boot up. It doesn't seem to matter if I boot into Android Auto or not. Basically, it occurs what seems like randomly.
Needless to say this is a VERY frustrating issue, and it worries me that it might be causing damage to my speakers. The popping noise is at full volume regardless of where the volume is adjusted to.
The only "solution" I've come across is to flush the ECU (disconnecting the power from the battery and touching the positive wire to the negative wire). This was a suggestion offered by the dealer I purchased the car from. While this does seem to fix the issue on the next start up, it flushes all of the settings for every electronic in the car. This means I have to drive the vehicle up to 12 mph to allow for recalibration and then power cycle the car so all the warning lights turn off. Obviously, this is not an acceptable solution to the issue, and the effects do not last long. Last night, when I turned the car off and back on to remove the warning lights, the loud popping noise came back on that start up!
Please let me know if any of you have experienced a similar issue, and if so, what did you/the dealer do to fix it?
