I guess this has been confirmed with HondaHack, then. Did you both do the web browser version?Just saw this thread. I have the same issue. The compass is gone as well as turn by turn. The instrument cluster is blank. I just opened a thread in the audio/nav/electronics area to hopefully get more feedback from people.
Yes I did the web browser versionI guess this has been confirmed with HondaHack, then. Did you both do the web browser version?
What version are you running with this issue? I will check later today on my car.Yes I did the web browser version
Where did you come across those release notes? I will have to check my version but I am assuming it is the latest since I just did the honda hack via the web version last week.What version are you running with this issue? I will check later today on my car.
By the way, there is a new version of HondaHack just released with the following notes:
Honda Hack 4.6.3
Oct 10, 2018
Have you tried it?
- Play navigation audio in separated guidance channel so navigation apps (except Google Maps) can work together with FM/DAB/CarPlay media sources.
- Add support for Google Play Services, Google Play Store, YouTube and etc.
Also saw the issue is acknowledged and apparently dealt with in the previous version:
Honda Hack 4.4.8
Sep 11, 2018
- Show navigation directions in the Instrument cluster of Civic.
- Add an option to restore the last used function at startup.
Release notes can be found on their website or here: http://www.autohack.org/release-notes/Where did you come across those release notes? I will have to check my version but I am assuming it is the latest since I just did the honda hack via the web version last week.
Interesting. I installed Oct 5th honda hack pro via the web. After seeing your post I checked the version and it is 4.3.6. However when I had honda hack check for updates it said I was running the latest version.Release notes can be found on their website or here: http://www.autohack.org/release-notes/
If you installed it last week, there is probably an updated version already since the last one was released yesterday.
I used the Garmin navigation on the headunit into work just now and it showed the prompts on the dash display just fine. The version I had was 4.2.9 which is strange since I just did the update last week and thought I had 4.4.8.Interesting. I installed Oct 5th honda hack pro via the web. After seeing your post I checked the version and it is 4.3.6. However when I had honda hack check for updates it said I was running the latest version.
