Looking to get new tires without rubbing help
Aegean303
Co
Civic Touring
I was wondering what tires would be best and will it rub?
Looking to get 18x8.5 38 for a 2016 touring
Summer tires 225/40r/18
Will this setup rub? And I’m on stock suspension.
Don’t really understand the “numbers”
Appreciate any feedback
GoldClass
Singapore
Civic Hatchback
You will be perfectly safe on stock suspension along with the wheel and tyre spec.
With that wheel and tyre spec., you can even afford to lower 1” (on Pro kit) and look just flush. But if your ride always on full load, then keep as stock suspension.
Discount Tire
Arizona, USA
discountti.re
All Things Honda
As GoldClass mentioned this set-up will fit. If we can help please let us know.
Aegean303
Co
Civic Touring
thanks :D
And btw what’s the difference between
225/40r/18 and 235/40/18?
Was looking through other threads and the 235 seems more popular?
Go with 235. Not only is it wider, it is a better fit on the 8.5" wheel you want and will keep your speedometer accurate.
Aegean303
Co
Civic Touring
Oh ok, but would the 235 cause it to rub? Or would I still be fine?
GoldClass
Singapore
Civic Hatchback
‘Wider’ gives more road contact and enhance braking distance. Aesthetically, look more ‘meaty’.
235/40 will still very safe on stock suspension along with your wheel spec.
You will not regret with 235.
Honda Civic 10th gen Looking to get new tires without rubbing help 6C40FE4E-A24D-423C-A5CA-508FFF8992ED
