Lightweight 15" wheel/tire recommendation
  1. 460cidpower
    460cidpower Member
    Mar 3, 2019
    26
    Occupation:
    Water treatment plant shift supervisor
    Spring Hill, FL
    Ken
    S2000, '19 Si coupe, '17 F-150
    I have '19 SI. MAperformance has a small brake kit that says it will allow the SI to have 15" wheels. Tirerack recommends 15x6.5 wheel with a 215/60R15 tire. The stock 19" tire width is 9.3" vs 8.5" of the 15". Will that hurt the handling a lot? Could anyone here suggest affordable lightweight 15" wheels/tires? Thanks!
  2. REBELXSi
    REBELXSi Señor Member
    Aug 12, 2018
    1,742
    1,573
    S/E PA
    '18 Si Coupe
    Sorry I don't have any actual useful input but why do you want to run such a small wheel on the Si?
  3. OP
    460cidpower
    460cidpower Member
    Mar 3, 2019
    26
    Occupation:
    Spring Hill, FL
    Ken
    It's my daily driver, I want the weight savings, cheaper tires and better ride quality.
  4. zhendexing
    zhendexing Senior Member
    Aug 26, 2018
    115
    119
    Chicago
    Dee
    2018 civic si coupe
    17” wheels are pretty light, a good set of 17” wheels with 235/45/17 tire should be 38-40lb.
  5. racer
    racer Senior Member
    Jul 31, 2018
    641
    387
    Virginia
    Dave
    2018 Civic Si sedan.
    A curious solution to a problem I didn't know existed. Most of the time, folks are looking for larger brakes to better handle heat or for appearance. But you've decided to go the other way. In fact, the only reason I could see why folks would want this is if they are building a "drag car".. small brakes.. small light wheels for acceleration, but you seem to simply want to improve your street ride.
    Of note, 60+ series tires will make the car handle less crisply.
    Of note, narrower tires (215 vs the OEM 235) will also make the car handle less crisply.
    I would likely consider lightweight 17" wheels and keep the OEM width/offset.
