Most likely has to do with a bad (or insufficient) Ground for the H11 headlights. Did you LED H11 bulbs come with a ballast? If so, you may need to find a better grounding spot for the ground wire coming off the ballast.
I had the same issue when I had a cheap chinese LED’s installed. I replaced it with Hikari’s LED set and it fixed it. Suggestion below me could fix you issue too.
I had some Oedro LED's that did the same thing.
I think it was the fan causing the static noise.
Have since switched to Katana LED's, and no fan noise or static now.
