LED Footwell Lights
  1. lucashend
    lucashend Senior Member
    Jan 12, 2016
    155
    65
    Upstate New York
    2016 Honda Civic EX-T
    I installed an RGB LED light strip under the driver and passenger side footwells. For now, it is wired to the 12V port, which means when the car is on, they are on, and when the car is off, they are off. I think it would be nice to wire them in with the daytime running lights or something, and I would free up the 12V port. Has anyone done this, or have any insight as to how to wire into the fuse box?
  2. dc2turbo
    dc2turbo Senior Member
    Jan 27, 2016
    2,921
    2,032
    usa
    civic,teg
  3. cjrcalica
    cjrcalica Step Ahead.
    Feb 24, 2016
    74
    Glendale California
    2016 Honda Civic Ex-T
    let me see how that looks, i kinda wanna do the same thing
  4. OP
    lucashend
    Jan 12, 2016
    155
    65
    Upstate New York
    Triple_peaz, HondaReese23, splvda and 3 others thanked this.
  5. cjrcalica
    Feb 24, 2016
    74
    Glendale California
    Thats so dope! Whered you get those?
    lucashend thanked this.
  6. OP
    lucashend
    Jan 12, 2016
    155
    65
    Upstate New York
    These are the ones I got this time.
    https://www.amazon.com/dp/B006U5SE7U/ref=cm_sw_r_cp_awd_ntk0wb6PA41RS
    My last car I just got a roll of LEDs, cut them to size, then soldered and whatnot to make them work. This car I opted for a pre cut kit and it was way easier to work with. The kit listed above is highly recommended. And it is multicolored so you can match the color to the in dash touchscreen color of your choice.
    CE1_nobling and cjrcalica thanked this.
  7. CivicNut
    CivicNut Senior Member
    Nov 2, 2015
    179
    91
    Brampton, Ontario, Canada
    2016 Civic EX-T (WOP), 2011 Ford Escape
    Sweet!
  8. cjrcalica
    Feb 24, 2016
    74
    Glendale California
    any video tutorial you use lol or pictures lol on how it was done?
  9. Mr.Brown
    Mr.Brown Senior Member
    Feb 15, 2016
    183
    Brandon, FL
    2016 Honda Civic EX-L Black
    that bin underneath where the 12v is located seems perfect for aftermarket upgrades like this without having visible cables.
  10. kered424
    kered424 Senior Member
    Dec 30, 2015
    149
    100
    TX, USA
    2016 Civic EX w/ Honda Sensing
    I just installed red LED footwell lights today that turn on with the parking lights.
    LilToTo17, HondaReese23, itbedave and 8 others thanked this.
  11. cjrcalica
    Feb 24, 2016
    74
    Glendale California
    Whered you get that?
  12. kered424
    Dec 30, 2015
    149
    100
    TX, USA
    I bought red LEDs from ebay and wired it up to a circuit that turns on with the parking lights. These are the LEDs I used: http://www.ebay.com/itm/4x-1LED-T10...ash=item2359ad3a92:g:dtQAAOSwWnFWBL-~&vxp=mtr
    You don't have to use these LEDs, but in my opinion these LEDs are the perfect brightness (and incredibly inexpensive). In my previous car, I had blue LED strips, and they were extremely bright at night, which was a distraction to the extent that I had to add a resistor to bring down the brightness. These, however, give a pleasant and subtle (but noticeable) glow for night driving. And in case anyone else is thinking about doing the same, I tapped into the gray wire on a harness by the interior fuse box. As far as I can tell, this gray wire supplies power to the overhead blue ambient light on the map light assembly. This harness is immediately adjacent to a yellow harness, and you want to splice into the gray wire. Sorry for the bad picture. There's not much room to work with down there.
    RufflesSCO, itbedave, HatchPanda and 3 others thanked this.
  13. OP
    lucashend
    Jan 12, 2016
    155
    65
    Upstate New York
    Nice. Just as another thought, you could always put a dimmer on them so you could brighten in during the day and dim them during the night. That's what I ended up doing on my last car
  14. kered424
    Dec 30, 2015
    149
    100
    TX, USA
    I've thought about it. I had a dimmer in my previous car before I replaced it with a permanent resistor. Since I wired the LEDs with my parking lights, they never come on during the day anyway, so I don't need them to be bright.
    But thanks for the suggestion :)
  15. Wrecks
    Wrecks Member
    Feb 6, 2016
    Virginia
    2016 Civic LX Automatic & 2006 CR-V
    Why didn't you use an "add a fuse" and plug right into the fuse box on the left side of your picture?
