Crab
- Sep 27, 2018
- 4
- 36
- 25
- NW Florida
- 2018 Civic Si, 2002 Accord EX-L, 2003 Dodge Dakota
Hello everyone,
I created this spread sheet to simplify my LED setups. If you would like to use it also, select file > make a copy. This will place a copy in your google drive.
Duplicate master sheet & rename
Set your trigger (ect, iat, vss, RPM, map, etc) from the drop down.
Set warning type from the drop down.
Select custom color in KTuner software to record R,G,B values
Adjust and record limit settings
I have included my current LED setup on sheet 2. It operates as follows:
LED 1: When ECT is below 149; LED blinks blue. 150-220 is a sweep from a dim green to a slightly brighter orange.
LED 2-3-4: Sweeping shift light. All LED's start green and sweep to orange-red before reaching warning level with an intense red blink. This still needs some work on limits.
LED 5: Gives a vague idea of IAT. Could definitely use some more work on range & color.
Sheet: https://docs.google.com/spreadsheets/d/1dmktnuaGPfTHqjKPQyl6u75TpWV4J6Yp-4qQLNCHFVk/edit?usp=sharing
Gif of my setup: https://imgur.com/a/MsMBaDg
Hope you enjoy,
Crab
Hope you enjoy,
Crab
