siczy
How do we get that? Petition?Maybe some time in the future. They don't give us open access to bluetooth connectivity.
did you use the code that's on the actual ktuner as your password in the app?I've personally tried everything and cannot connect to tunerview. I did the correct protocol, tried every combination of passwords to try to connect to it. I've been trying for weeks, already feel like I wasted money and time on that app
Yes, the code is after the KTVK1, it's a 5 digit code. I've tried every combination I could, nothing workeddid you use the code that's on the actual ktuner as your password in the app?
The 5 digit code worked for me on my V1.2!? It took me a long time to use all 5 digits. I kept thinking 4 should work.Yes, the code is after the KTVK1, it's a 5 digit code. I've tried every combination I could, nothing worked
Did you ever contacted us for support? I can say that most of the people who argued about a problem with TunerView, 95% it was user error. It can be a problem with the android device or the unit. If you have any problem, contact for support. Thats the easiest way to find a solution.I've personally tried everything and cannot connect to tunerview. I did the correct protocol, tried every combination of passwords to try to connect to it. I've been trying for weeks, already feel like I wasted money and time on that app
Don't forget to set the correct V1.2 or V2 protocol. Common issue that most people don't know that TunerView is not just for KTuner and/or KTunerFlash. With purchasing KTuner protocol you will get the KTuner R1 protocol too which is for RSX based InECU hardware. It's totally different and not working with KTunerFlash V1.2 or V2.
We all set.
It should actually blink green when plugged in. I can't tell who you are so I have no context about an email saying you did everything right. Still not really clear on your issue so send another email.Yea I set the protocol for my Ktuner V1. I will double check again. I emailed Ktuner about it, they said everything I did was right. Maybe you have to set something when you do the tune on a laptop? That's my only thought on it. I essentially chose the map I wanted and loaded it, I didn't even set anything else. Took me all of 10 minutes. My Ktuner is lighting up solid green when I have it plugged into my car
When can we expect the V2?It should actually blink green when plugged in. I can't tell who you are so I have no context about an email saying you did everything right. Still not really clear on your issue so send another email.
Any Idea if this would be any time soon, trying to decide if I should get a v1.2 or a v2Maybe some time in the future. They don't give us open access to bluetooth connectivity.
For Apple support? The unit would likely need a refresh before this can happen.Any Idea if this would be any time soon, trying to decide if I should get a v1.2 or a v2
Thank you! That is awesome news for the 18 guys!For those having a 2018 civic and can't access the developer mode. There's another working method that is not publicly released yet. It does the rooting by the browser. I just did it on a 2018 Civic Si. Once Tunerview/KTuner release there beta software out to public. You can install it on all 10th gen civic with the touchscreen
