KTuner Updates: Si Advanced VSA, 18 MY Map Switching, And More!
Gotch
Rob
2022 Si
Boost by gear quick drop downs also available.
It would be cool if the TSP tune had some user quick adjustments but I contacted Derek and he said it wasn't do-able.
Nathan le
Honda boy
2016 civic touring
Honda Civic 10th gen KTuner Updates: Si Advanced VSA, 18 MY Map Switching, And More! 3DA30371-D92C-4B47-8ABD-34D6509549E9
Gtman did you update your ktuner software ? My doesn’t have the advanced VSA feature any inputs thanks
Nathan le...
No, I haven't updated yet. I noticed you're using 1.0.9.1...that's the same older software I'm using.
Shouldn't the latest version be 1.0.9.2?
Nathan le
Honda boy
2016 civic touring
I have stock down pipe, you'll be fine. Im not trying to roast the tires from every stop sign so itll be ok
Hi, dallasjhawk tsp stage1 bbg should I leave it custom or choose whatever boost levels , which one work best? Thanks for any inputs.
dallasjhawk
Royse City, TX
In TSP I'd leave it alone. You can enable Advanced VSA to take care of the spinning tires now.
dallasjhawk
Royse City, TX
Cool, thanks man. Do you know which level of advanced VSA is best for DD?
I actually went Aggressive ignition but probably the middle one is a good middle ground for a daily.
fenix-silver
Central PA
2019 Si
When you update the ktuner software, do any maps that you previously used get updated w/ any new tune changes automatically, or do you need to create a whole new base tune and make any of your previous changes before reflashing? Hope that makes sense.
