KTuner Updates: Si Advanced VSA, 18 MY Map Switching, And More!
  1. KTuner
    KTuner Senior Member
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    #1 KTuner, Apr 4, 2019
    Hello Fellow Enthusiasts!
    It is with great pleasure that we bring you a release full of progress for the 10th gen platform! We have been very busy and very quiet with everything happening here, but there is so much in the works!
    This update is live on the website and available now!
    For the Si (All 17-19):
    New P2565 Wastegate Disable For Use With Aftermarket Turbo Kits Like The PRL Big Turbo Kit and MAPerformance Kits. If you used the previous option, uncheck it, then check the new one instead. Cleaner full disable and keeps Sport mode fully operational. The old disable is still available in the event something else arises.
    Advanced VSA Control (If you know someone with a 2.0T Accord, this is available for them too)
    Tired of the VSA system overreacting? We've had this option in development for some time and it's a great tie in to the factory VSA system. Maintaining some level of throttle intervention, we have built on the ECU's control of ignition during loss of traction. Simply enable the Advanced VSA feature in Quick Enables and then select your level of balance between ignition and throttle for the Advanced VSA Control Strategy under Quick Adjustments.
    Please note in a situation that calls for it, like if TPMS says your tires aren't equal or you're on a spare, Advanced VSA can be disabled by enabling Cruise Main on the dash.
    Advanced VSA Control will make its way to Non-Si platforms soon, as we may change or add options based on the feedback for the Si platform.
    Link to Advanced VSA help page: http://ktuner.com/KTunerHelp/advanced_vsa_control_strategy.htm
    For the Non-Si
    For Use With Aftermarket Turbo Kits Like The PRL Big Turbo Kit and MAPerformance Kits. If you used the previous option, uncheck it, then check the new one instead. Cleaner full disable.
    Available Today For These ECU Models, available soon for others:
    • 5AA-A0x
    • 5AA-A57
    • 5AA-L58
    • 5AA-A67
    • 5AA-L68
    • 5AA-C0x
    • 5AA-C57
    • 5AA-C67
    • 5AA-K0x
    • 5AA-K1x
    • 5AA-K2x
    • 5AA-X0x
    Hatchback Models
    • 5AN-95x
    • 5AN-A0x
    • 5AN-A1x
    • 5AN-A5x
    • 5AN-B5x
    • 5AN-L5x
    • 5AN-A6x
    • 5AN-L6x
    • 5AN-C0x
    • 5AN-C1x
    • 5AN-C5x
    • 5AN-K6x
    Multi-Map Switching (CVT and MT) And Adjustable Launch Control (MT Only) Added To These Additional ECUs:
    • 5AA-A1x
    • 5AA-A7x
    • 5AA-A8x
    • 5AA-C1x
    • 5AA-C8x
    • 5AJ-A5x
    • 5AJ-L5x
    • 5AJ-L6x
    • 5AJ-L7x
    Matthyahuw, fretcrazy, Bummslut and 17 others thanked this.
  2. dallasjhawk
    dallasjhawk Senior Member
    Oct 3, 2016
    3,799
    3,695
    Arlington, TX
    2016 Civic EX-T, 2004 Acura TSX
    Always busy in the lab it appears, even if you are quiet for a while! So glad to see this VSA feature, cant wait to see it on the base models and R as well :)
    Scarlet and gtman thanked this.
  3. hobby-man
    hobby-man Senior Member
    Jun 20, 2018
    640
    434
    Mississauga, ON
    2018 Sport Touring Hatchback 6MT
    When can I expect to get OTF map switching for my MT hatch? Been dying to try it out!!
    5AN-C360
  4. OP
    KTuner
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    That will likely be in the next series of ECUs to get it.
    LilToTo17 and hobby-man thanked this.
  5. givemeadollar
    givemeadollar Senior Member
    Sep 3, 2018
    245
    150
    Multiverse
    Matt
    2018 Civic Si Coupe
    @KTuner Does this mean we will be able to dyno without the pedal dance now?
  6. hobby-man
    Jun 20, 2018
    640
    434
    Mississauga, ON
    Can you give me a low-level rundown on how that process works? What makes the various ECU softwares different? Do you have to re-code these adjustments into each batch/type of ECU? It's very interesting.
  7. jred721
    jred721 Senior Member
    Mar 21, 2018
    1,261
    835
    Northern Virginia
    James
    '18 Honda Civic EX, '18 BMW M550i, '13 Mercedes ML350
    You can always count on KTuner to continue killing the game. Advanced VSA definitely seems like a cool feature to supplement the tuner.
    Si Stuart, Triple_peaz, Scarlet and 2 others thanked this.
  8. OP
    KTuner
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    There are many different softwares, where things are compiled differently and thusly everything is in different places. That means it takes work to add features to, because it's not the same.
    Si Stuart, Triple_peaz, hobby-man and 3 others thanked this.
  9. ebatr24
    ebatr24 Senior Member
    Jan 20, 2018
    240
    154
    Oregon
    2018 Civic Si Coupe
    Are all the Advanced VSA Control Strategies going to be safe to use? Wondering if there is some pros and cons to each option. Also wondering what happens when we turn traction control off via the button with this option enabled, previously if I understood it right the VSA was still partially on even with just traction control disabled via the button.
  10. OP
    KTuner
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    Excessive usage with a catted setup could cause potential issues down the road.
    Still partially disables intervention. Think of this as stacking on top of the existing functionality. The button still partially removes throttle intervention. Pedal dance removes throttle intervention.
    Evofc1407, Myx, LilToTo17 and 1 other person thanked this.
  11. ebatr24
    Jan 20, 2018
    240
    154
    Oregon
    2018 Civic Si Coupe
    Nice I am catless so I don't have to worry too much about that. Other than that it shouldn't cause a problem? I wondered this about the Hondata traction control they recently added as they mentioned that at the higher power levels it would make the car misfire. Now I can't wait to wake up and go be a hooligan with this.
    repeet thanked this.
  12. gtman
    gtman Senior Member
    Oct 27, 2015
    5,116
    5,187
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    Hey JR... can you elaborate on what's "excessive" usage and what the potential issues are? Thanks.
  13. OP
    KTuner
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    It retards timing. That's not something you want to do over and over for long periods of time. Same thing would go for anti-lag.
    LilToTo17, Scarlet and dallasjhawk thanked this.
  14. OP
    KTuner
    Jul 10, 2017
    1,835
    2,369
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    LilToTo17 and gtman thanked this.
  15. Abdool
    Abdool Senior Member
    Aug 17, 2018
    198
    38
    canada
    abdool
    2018 honda civic touring
    She will there be more options for 2018 touring?
