KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
Ktuner answered to me.
- We don’t change anything under 1500 RPM. As I mentioned in the thread, if you find a quick adjustment combination that makes that section too aggressive, dial it back. -
Now, has anyone tested a raw starter21 without touching any adjustment? If I remember correctly I tested it and still happend.
I know that:
- Happens with TSP stage1
- Happens with starter21 without pedal adjustments and without revhang disable.
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
With ktuner stage 2, no problem.
It's a shame because, removed this problem, ktuner starter 21 with adjustements is a bomb.
KTuner help us please!
SilverArrow
Italy
Tonight i noticed that these stuttering are more frequent with the cool engine. With the hot engine, these stuttering are less present.
Has anyone else noticed this?
kytos
Marcos
Madrid - Spain
Yes, when the engine is hot is smoother but still present and when the engine is cold it is more reproducible.
SilverArrow
Italy
Hi guys,
has anyone noticed stuttering with this maf configuration, "factori maf w/scaled top end calibration"?
Honda Civic 10th gen KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come Screenshot_20191029-072637~2
kytos
Marcos
Madrid - Spain
Hi guys,
I didn't tested it for stutter but yes. That souldn't cause stutter.
SilverArrow
Italy
Sorry kytos, i don't understand.
Think you that this problem is present also also with "factori maf w/scaled top end calibration"?
kytos
Marcos
Madrid - Spain
I mean I tested the new MAF calibration, I was not looking for the stutter but for better air fuel ratios at WOT. That MAF calibration souldn't cause or fix the stutter because it doesn't change anything at low rpm (low air flow), and yes I experienced the stutter with the "factory maf w/scaled top end calibration"
SilverArrow
Italy
Thanks kytos, now I understand.
We can only hope in a solution from KTuner.
kytos
Marcos
Madrid - Spain
The problem is we don't know what is causing this and @KTuner believe it's some quick adjustment being too agressive (which i doubt it is). I need to do more testing myself before reporting to ktuner and hope there is a solution.
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
If you can figure out what the combination is that is causing it I can take a deeper look. Unfortunately since there are multiple settings controlling the multiple ways the ECU controls things, if a combo alters it in a way you don't like you will have to alter your settings to something that you're ok with.
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
I found some time to check on Kyto's logs. Check that it's not only TPS.CMD that varies. It is also knock retard (KControl is steady 0.49) which goes from 0 (normal at this amount of load) up to -7 and actual timing (IGN) varies from 0 to 14 degrees.
TPS is steady, TC Target is steady.
If it helps at all, building a custom map based on the "factory base calibration" seems to work a lot better even if you copy the boost tables from the starter21 "as is". Anything built from the "starter 21" will stutter.
@KTuner hope this observation helps (in any way …)
Just curious here. On my US car, I haven't experienced this stutter. I've used the Starter 21 with many different quick adjustment combos. No low speed stutter. I don't get the stutter on the TSP tune either. What's the difference in the US versus Euro setup?
turbo lover
Civic Hatchback Sport Touring
I get stutter on both TSP Stage 1 and Ktuner 21 PSI. The Canadian setup might be different than the US one too. I haven't really looked into it at this point, but now I'm becoming more curious.
