KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come
Andre80
white civic
Europe
Civic X 1.5 sport +
Volevo sottolineare qualcosa, stavo usando il controllo della velocità di crociera a circa 70 km / h, e ho notato per la prima volta che accelera e balza continuamente per mantenere la velocità, ho provato a spegnere il condizionatore d'aria e tornare alla normalità , alla velocità dell'autostrada è tutto in ordine
questo non era mai successo prima dell'aggiornamento, ed ero sulla mappa da 1 a 16 psi
Andre80
white civic
Europe
Civic X 1.5 sport +
boe921
sinan
istanbul
2018 civic hatchback sport+
when will you issue new updated for 5AN-G8 ecu.stuck in initial support is very bad.
David228cx
David
Spain
What tables are we missing on european ECU's ? Mine is G23 iirc
Even with the TSP tunes (it also happens with the base ones that come with ktuner), there's some stuttering on low rpms when accelerating gently. Mostly from 1.5 K to 2k rpm.
When asked Derek about this, he mentioned that there were some tables missing on the european ECU models.
When will they be implemented? Any plans for now?
Thank you!
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
I'll try to datalog that asap. This happens to all european ECU's like G23, E13 and some more... But it happens from 1000 to 1500, specially from 1200 to 1500 where you land at low speeds when changing from 1st to 2nd gear and sometimes but more avoidable at 3rd gear under 1500. This happens when you are soft with the trottle, this doesn't happen if TPS is 1% or +60% or if you burn the clutch to get over 1500 RPM, maybe ignition/load related. (I don't really know) @KTuner I will mail you soon.
Andre80
white civic
Europe
Civic X 1.5 sport +
THEREFORE, IT ALSO HAPPENS TO ME, EVEN LESS THAN EVEN STOCK
turbo lover
Civic Hatchback Sport Touring
This happens to me too,with Canadian ECU, I'll try to get some data logs.
kytos
Marcos
Madrid - Spain
well.. I did record it in video and datalaloged :) let's put it together and also send it to ktuner.
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
I notices that with ktuner tune stage 2 this issue is not present, but is present with tune starter 21 psi with improved adjustements and early spool enabled.
And if the issue were the early spool enabled?:hmm:
These are my actually parameters:
Honda Civic 10th gen KTuner Update: Map Switching Added To Many More ECUs, Non-Si Adv VSA, more to come IMG_20191024_200800632
kytos
Marcos
Madrid - Spain
It's not early spool, that happened to me with starter21 without it.
SilverArrow
Italy
Thanks kytos.
I don't understand because with tune stage 2 this problem is not present....
KTuner reads these posts?
