KTuner Unit is not on our system? 2.0 NA
jwitt12
Justin
North Carolina
2018 Honda Civic LX Sedan 6-Speed
Has anyone had this problem? Just got a Ktuner from a fellow forum member, unlocked and everything, and I know my ecu is supported cause I had a Ktuner previously. Every time I go to register it, it says the unit is not in our system? I’ll post a pic. Any help or advice would be awesome. I downloaded and installed drivers correctly to best of my knowledge.
Honda Civic 10th gen KTuner Unit is not on our system? 2.0 NA 5C4790F0-3950-48E5-ADB4-C8C70C68B0F1
caspar21
2018 Civic Si
south central ontario
2018 Civic Si
Wait what? Could you explain a little bit if you don’t mind?
connect ktuner 2.0 to the car and ktuner software and connect to internet. in the pulldown menu choose check for updates. it should update ktuner device as well as software.
then it should be able to work with your ecu.(as long as it is supported)
jwitt12
Justin
North Carolina
Okay cool, I have a v1.2 don’t know if that makes a difference
jwitt12
Justin
North Carolina
The unit was reported missing in transit by the original owner, but apparently showed up after 3 months so it has been released for usage again.
Yes it works great now, thanks!
Jambles
2017 Civic Si
Hi, did you just have to contact Ktuner support to get this fixed? I'm having the same problem but I bought a new Ktuner from TSP's site.
