Ktuner tsp no lift shift
Gforce81
Delaware
2018 CTR
I was looking for this setting today and cannot locate it. I'm using the Ktuner shelf map for Stage 1 DP 1st gear dampen map. Is it not available to edit on that map?
3925blue
Texas
2018 Honda Civic Si sedan
I set mine for closer to 4200 because I don't tend to run this engine out to redline, honestly. I'll shift on the high side if I am trying to boost it up a bit, but this engine isn't as exciting at 6000 as it is at 3000.
Mcclaughry95
500hp is the goal.
Ryan
Central, Pa
18 Civic Si
Anyone happen to know where they have the limit set for? Didnt see much drop while shifting and could smell the clutch from the slipping.
Micah
Toms River, NJ
Did you remove the clutch delay valve? If not you are going to have a crap ton of slipping and thus burning of the clutch.
PowerPerLiter
Specific Output
Midwest
I have used the nlts almost exclusively since 3k miles on 23psi tunes. 19k now. The rpm drop point is absolutely critical. Much more sensitive than both companies say it is and is very shift rpm dependent. 4900 is the sweet spot when shifting a little after 6k. No slip. no jerk. It is and should be smooth as glass when you set it up to match YOUR shifting correctly. This is with the clutch delay valve still in place. Without it would change everything to do with this so if anyone reads this with the delay valve removed 4900 may not be ideal....Im not sure.
Except for D-robs tune which I think I remember seeing its programmed to default to 5000 during nlts. Correct me if Im wrong.
Im almost positive the no lift to shift rpm in the "canned" tunes is assuming your shifting just before the limiter. Which most do not. Those that do should look at recorded data logs and I would bet they are barely shifting at 6100 per the ecu. The tach it seems is about 200rpm ahead of the actual rpm. Or the way human vision works make it seem this way anyway.
Gotch
Rob
2022 Si
Set mine at 4875rpm which is THE ABSOLUTE sweet spot! J/K, I experimented with set points for a bit before setting it to 4900. Shifts feel like an auto trans they are so smooth. Zero clutch slip as well. Thanks @PowerPerLiter for the recommendation. That setting suits MY driving style perfectly.
PowerPerLiter
Specific Output
Midwest
No problem. I haven't flashed the car 100 different times over the past year for nothing! Lol
JustAHatchback
Daniel
Charlotte, NC
2018 FK7 Sport 6MT
I know this is an old thread but I cannot get WOT shifting/no lift shift to work on my 2018 hatch. I'm wondering if this is an Si-only feature or something... it's really frustrating trying to test it out and the tach just goes straight to redline lol. Does anyone else have this issue? I've tested it on both TSP Stage 1 and custom KTuner maps.
JustAHatchback
Daniel
Charlotte, NC
2018 FK7 Sport 6MT
The ECU needs to see the switch fully depressed in order to activate.
Ahh, okay. I have a clutch pedal stop set up and the switch doesn't engage unless I push the clutch in super hard. I'll adjust the switch sometime and see if I can get it to work. Thanks!
