d1zguy
- Apr 6, 2017
- 23
- 769
- 369
- VA
- 19' Mustang GT Premium
Hi All,
After a while I was able to get my STFT values within +- 3% on a stock MAF. On my particular car LTFT's were 7% at idle and lowered to about 3.54% on the highway.
I used
http://vimsh.github.io/mafscaling/
Got in touch with the developer and was able to use the tool on Maf.Hz cars. Which my SI is. EX-T's and others use a Maf.v style maf and the tool will work out of the get go. The tool will be more useful for those that want to use a larger MAF housing, etc.
Recommended way to tune is to turn off LTFT's by settings LTFT fields in ktuner to 0%. Then logging and entering in the parameters on the tool. I was having a hard time scaling the upper end of the scale as I was not collecting enough data points but the trims were about 3-4 percent.
I ended up scaling the entire curve by 5.34% and that got me within +-3% 0-5 is the best we can aim for.
Misc:
Looking at logs it looks like the SI is always in closed loop showing Fuel_Status 2 under the logs for OL. This may be different on EX-T cars.
In addition it's best to just turn off LTFT's. The LTFT strategy on these ECU's is not the same as others and results in running too rich when the AFR is actually okay. i.e idle for too long at 8% STFT will make the LTFT increase to 8%. Then cruise at 45mph in 5th gear and stft will show 3% but will still be too rich at 8%. and will be running 5% richer than it should be until it cruises for longer at 3% and goes back down.
Short Term Fuel Trim (STFT): is an additive correction % the ECM is using to actively modify the injector pulse-width based on lamda correction (requested vs. actual) at idle and very light load. Once recorded fuel trims pass a preprogrammed threshold the LTFT is increased and the STFT cycle is reset and continues to recalculate based on the newly configured LTFT.
Long Term Fuel Trim (LTFT): is a multiplicative % calculated into the injector pulse width. LTFT trims are factored across the whole spectrum of engine operation increasing with relationship to engine load.
I used
Misc:
