Ktuner problem: 19.5 psi map only hitting 13 to 16 psi?
Honda_RacerX
2019 Si
  • Banned
  • #1
I uploaded the basemap for the 19.5 psi but it only hits a max of 13 to 16 tops. Has anyone else had this issue?
I also improved throttle response and upped the turbo responsive ness to level 2. I can feel those changes, but I dont understand why its not hitting the correct boost target.
I reflashed a few times and still the same issue.
EDIT* fixed. i was originally trying to use the factory map and change the boost targets in the quick adjustments manually to 19.5 psi. that doesnt work, at least for me it didnt. it still targeted factory boost.
so i flashed the actual 19.5 map and it hit the target. im not sure why changing the boost target manually doesnt work.
but im fine just uploading the actual 19.5 basemap.
Is there any way you can post a datalog? This was at WOT? We need to see if it was actually targeting 19.5 and some other things to diagnose.
Honda_RacerX
Honda_RacerX
2019 Si
  • Banned
  • #4
i have the v1.2 so i guess i will do it sometime when i can get my laptop hooked up while driving.
It's important to do that to see what's going on. If it's targeting 19.5 but only hitting 13 you could potentially have some real issues. Of course depending on a lot of factors, it may not have been targeting 19.5...
Honda_RacerX
Honda_RacerX
2019 Si
  • Banned
  • #6
What type of issues, generally speaking?
And what factors would prevent it from targeting 19.5?
Davesxx01
Dave
Madison Wisconsin
‘19 CR-V
Exact same problem I’m having! Been lurking these forums for a while. I have a ‘19 CR-V. Base 18.5 map was actually slower than stock (tested with a “Dragy” performance meter) 19.5 map is .2 faster in the 1/4. Not hitting proper boost, only hitting 16.
I do have a V2 and will Datalog if gtman can look at it.
This forum is so much better than the grannies on the CR-V forum. As I have the same motor as the SI I’m learning a lot from posts from gtman and others!
aldo
Al
Midwest
2018 Civic Si Coupe
Sounds like the map isn’t loaded, try loading the 21 map see what happens
Honda_RacerX
Honda_RacerX
2019 Si
  • Banned
  • #9
Onboard logging can be done from the V2 directly or from the software with a laptop/V1.2...
You then can upload the KTuner datalog file as a .zip here and I'd be glad to read it.
i recorded a datalog today but it is a kdlg file.. how do i change it to a zip file?
Save it to your computer. Then right click the file on and there should be an option to extract it to a .zip file.
Davesxx01
Dave
Madison Wisconsin
‘19 CR-V
Datalogged, saved, no option to convert to .zip? gt, will you look at mine also and give a thought?
Happily but you need to save it to a .zip file for viewing here. Or, save it to a storage site online and link the address to the .kdlg file.
When you right click the file saved to your pc, there's no option to "send to compressed zip folder"? That's something all Windows pc's do.
Unfortunately, you saved and exported it as an Excel spreadsheet. Save it as regular Ktuner datalog (.kdlg) file. That way I can see things in real time with the KTuner app.
