Ktuner No Lift Shift Settings
  1. Gforce81
    Gforce81 Member
    Oct 1, 2018
    35
    Delaware
    2018 CTR
    Hey everyone -
    Looking to improve my 1/4 mile times and am going to enable the feature in Ktuner that lets you keep foot on gas and only use clutch. I believe, if understanding correctly, that you need to establish RPM close where you land in the gear change. Does anyone have settings they've found to work well?
    I'm planning on mounting a go-pro so I can see the engine speed between shifts and will start @100 RPM higher as a baseline. Happy to share results as I get more practice but wanted to enlist those more experienced as well. Only had the car for 3 weeks so much to learn!!!
  2. PowerPerLiter
    PowerPerLiter Specific Output
    Jun 6, 2018
    266
    124
    Occupation:
    Service Consultant
    18' Si Coupe WOP
    1500 rpm less than the shift point should be a good start
  3. OP
    Gforce81
    Gforce81 Member
    Oct 1, 2018
    35
    Delaware
    2018 CTR
    I had read somewhere (can't find the post) that Ktuner recommended 100 rpm over. Can you elaborate on why you would recommend 1500 under?
  4. PowerPerLiter
    Jun 6, 2018
    266
    124
    Occupation:
    Service Consultant
    18' Si Coupe WOP
    well I dont use ktuner yet but from what I know there is a cut and recover for most of those settings. the way my hondata works is basically a "cut until" X RPM. fuel cuts until 1500 ish lower than my shift rpm so redline being 6500 mine is set to 5000 and when I nlts it cuts until 5000 and thats about where the shift normally re engages during a "normal shift"
    ninja edit: The "cut" rpm really wouldnt apply to this because its just using the clutch input switch with the tps signal
  5. PowerPerLiter
    Jun 6, 2018
    266
    124
    Occupation:
    Service Consultant
    18' Si Coupe WOP
    Just noticed yours is an R....my apologies it may be completely different
  6. OP
    Gforce81
    Gforce81 Member
    Oct 1, 2018
    35
    Delaware
    2018 CTR
    No worries and thanks for the reply. Going to do some videos so I can see where the engine speed is per gear change and set it near there. Test and adjust. The fun is in learning lol.
