KTuner/Hondata and S mode (1.5t CVT)
Tobus
Australia
2016 Honda Civic RS
Hi,
I'm wondering what happens with "Drive (S)" mode after you flash with a KTuner/Hondata tune - does it become the same as D or is there still an difference (and if so how does it work)?
Following on, I've read with KTuner you can set the ECON button to effectively switch between normal/tuned maps, does either product have the ability to assign a map/settings to the "S" gear, so you can switch on the fly by shifting from D to S?
Toby
The tune has nothing to do with transmission modes. They work exactly the same after the tune. S will still rev higher in the powerband compared to D.
You can use the Econ button as a similar to stock tune (and switch between stock and tuned) but you can't map anything to S.
dldaves
Darius
Cary North Carolina
2021 Honda Civic Type R
so does eco mode work on tsp 1 tune?
Yes. You still can use that to switch to a lower power eco tune on the three maps.
