I see you have the V2, I havenāt had a code pop up yet, but have you tried using the KTuner V2 device to clear the code? thereās an option on the menu to do it where it says āclear codeāIs it me or do I not see an option to disable P0139 CEL in KTuner? Can someone point me in the right direction.
Thanks!
It clears the code but supposedly thereās an option to disable it from showing up according to KTuner, I just donāt see that option. I just donāt want to have to keep clearing it after every 50-60 miles of driving.I see you have the V2, I havenāt had a code pop up yet, but have you tried using the KTuner V2 device to clear the code? thereās an option on the menu to do it where it says āclear codeā
Scroll down the pageIt clears the code but supposedly thereās an option to disable it from showing up according to KTuner, I just donāt see that option. I just donāt want to have to keep clearing it after every 50-60 miles of driving.
Awesome! Thank you sir!
Thanks for posting! It is very interesting to see someone that has made some 100-200 runs! This is what I asked for in my thread āwhy is the ctr so slow?ā. My understanding was that a stock fk8 would do it in around 14sec, something that I feel is kind of slow for the power and weight. You are running very ideal conditions and high octane gasoline not easily available, maybe that is why you have so good numbers to start with? I have not seen anyone else post stock 100-200 in below 13 sec. I agree however that getting closer to 400hp on the crank should put this car closer or even below 10sec.Measured stock vs stage1, difference is only 1 second in acceleration 100-200kmh
Used Racelogic VBox Sport.
Stage1:
Iām using a Eurodynamic tune.If you had just flashed the ECU it was still initializing the sensor. On our flashes it does not target 14.7 while at higher load. Factory it does in some scenarios.
If you're using someone else's tune you'll need to ask them about any specifics. They don't start with our base tune.Iām using a Eurodynamic tune.
Got it, thanks.If you're using someone else's tune you'll need to ask them about any specifics. They don't start with our base tune.
No problem! Thanks for always responding to my emails!Thanks for posting!
Never a problem. I'll keep that in mind!No problem! Thanks for always responding to my emails!
If you need beta testers for anything, let me know. You'd get the best of both worlds since I know how to debug software AND my car
