Ktuner Civic Hatchback CVT problem
FK7Turkey
İbrahim Uğur
Turkey
18 Civic Hatchback 1.5 t Cvt
I have a civic hatch 1.5 t cvt (14k miles) A few days ago I was looking at Ktuner Log files. I noticed a problem with the third and fourth gear shifts.After the third gear quickly shifts into fourth gear and shifts back to third gear.The same problem exists at the beginning of the fourth gear. Anyone have opinion for the situation ?
Log file
Modifications
Ktuner 21 psi basemap
İnjen intercooler
İnjen Evo 1500 air filter
Dp and Fp
r.camlin
Rob
New Jersey
2019 Civic Hatchback Sport
There are no gears on the CVT. That sensor or display unit is irrelevant for you.
PEPSIFLAME
Dallas, TX
2020 Honda Civic EX Hatchback
CVT stands for Continuously Variable Transmission.
Gruber
Mark
TN
The CVT doesn't have gears but the whole range of transmission ratios is arbitrarily divided into several ranges called "gears". There is nothing wrong with the gear ratio going a bit back and forth even when the driver is trying to continuously accelerate. Depending on the sensed/computed conditions of rpm, speed, requested throttle, and the load on the engine, the CVT may momentarily go back in transmission ratio if the computer calls for more power/torque. This correction may be very slight, but it may show on the "gear" display as a "downshift" if the arbitrary transmission boundary is crossed even just barely. It doesn't necessarily mean that the ratio actually changed by a whole "gear" worth.
The problem is that the ECU/CVT is not able to predict the future and plan ahead, so it can only react to the varying current conditions. It is also programmed to favor the highest possible gear for fuel economy, so if this turns out to be too optimistic, it may need to correct down.
Muscleman
Rigby
Honda civic
The cvt doesn't have gears but why is there boost by gear in the map for the cvt?
Because the "virtual gears" represent certain ratios within the power band. For example, limiting boost in "1st" can help lessen wheelspin off the line.
Muscleman
Rigby
Honda civic
But but is it bad to put the highest psi in the first gear,
