Miha__
Hi,
I want to track back the exact moment that knock has been detected
Can you help me to recreate values within ignition table:
Goal is to recreate this table in excel, add use X in exact field that knock has happened.
For input data, i will use data logs in CSV.
So fields that are available are
Time(s) | RPM | MAP(mBar) | MAP(Conv) | TC,Target | TC,Press | MAF,v | MAF | PWMDC | TPS | TPS,CMD | CAM,CMD | CAMA | EXCAM,CMD | EXCAMA | AIGN | FDC | FP1 | STFT | LTFT | LAM | LAM,ADJ | LAM,CMD | FUEL,STAT | KNK,C | KNK,CTRL | ECT(C) | IAT(C) | VSS(KPH) | GEAR | BAT | VTEC
Does anybody know how to calculate tabulated ignition timing ?
Also X axis (LOAD) I want to confirm that it represents MAP(mBar) ?
