Knock Control .85
  1. wmayhue
    wmayhue Member
    Apr 2, 2019
    Virginia
    Will
    2017 Honda Civic Si
    Questions about Knock control. Im runnning basemap 19.5/21.5 dual tune. .85 is the highest knock control that I have recorded. When going light on throttle or driving in traffic it will drop lower, but is .85 an acceptable number or should i strive to lower this number. Reading around, it seems below .6 is the number to shoot for. Is running .85 likely to cause damage or am i fine with that number?
  2. gtman
    gtman Senior Member
    Oct 27, 2015
    5,622
    5,917
    Occupation:
    CivicX addict
    U S of A
    2017 Cosmic Blue Civic EX-L
    Having higher knock control number like .85 doesn't equate to any sort of damage you could be doing to you engine. Higher numbers mean timing is getting retarded so you have less power. There are a lot of factors such as octane, IAT's and load that determine K control. It's bound to go up temporarily if you push the engine hard.
    The real question is under normal driving, what's your knock control number? On 93 octane mine stays nice and low in the .49 range.
  3. hobby-man
    hobby-man Senior Member
    Jun 20, 2018
    658
    453
    Mississauga, ON
    2018 Sport Touring Hatchback 6MT
    Mine also stays steady at .49 under normal conditions/cruising on 91 octane @ 21 PSI tune
  4. OP
    wmayhue
    wmayhue Member
    Apr 2, 2019
    Virginia
    Will
    2017 Honda Civic Si
    I just got the Ktuner and had a full tank of 89 Octane in it, ill get 91 or 93 next time i fill up and see if that makes the difference. Also i will check back in with a normal drive without any hard accelerations.
    That boosted guy thanked this.
  5. KTuner
    KTuner Senior Member
    Jul 10, 2017
    1,909
    2,488
    Occupation:
    Engineer
    Chandler, Arizona
    J.R.
    2017 Si
    That will definitely make a difference.
  6. OP
    wmayhue
    wmayhue Member
    Apr 2, 2019
    Virginia
    Will
    2017 Honda Civic Si
    are there any negative side effects to mixing the octane levels? Like if i put 91 on top of the half tank of 89?
  7. gtman
    gtman Senior Member
    Oct 27, 2015
    5,622
    5,917
    Occupation:
    CivicX addict
    U S of A
    Absolutely none.
  8. CVCTURBO
    CVCTURBO Senior Member
    Nov 8, 2018
    436
    299
    Occupation:
    Welder, Metal Fabricator, Machinist
    VA
    2018 Civic Sport 6M
    Here recently I've had mine jumping all the way to .87ish in slow moving traffic. I also think IAT is a big factor bc when it was cooler I was always no higher than .55
    Now that my IAT is easily 90°+ I get these random high jumps in knock
    Also Sheetz 93 gas is terrible and I've had to use that lately so obviously could be the culprit aswell
  9. gtman
    gtman Senior Member
    Oct 27, 2015
    5,622
    5,917
    Occupation:
    CivicX addict
    U S of A
    Something to consider to stabilize K control for the warmer weather ahead:
    www.civicx.com/threads/from-hondata-to-ktuner-the-ongoing-review.29033/page-4#post-532825
    wmayhue, hobby-man and CVCTURBO thanked this.
  10. CVCTURBO
    Nov 8, 2018
    436
    299
    Occupation:
    VA
    2018 Civic Sport 6M
  11. OP
    wmayhue
    wmayhue Member
    Apr 2, 2019
    Virginia
    Will
    2017 Honda Civic Si
