BestCarEver
- May 2, 2016
- 9
- 97
- 33
- langley bc canada
- 2016 Civic LX HS, 2015 Jetta Trendline+
Bought the OEM remote starter on eBay. Genuine Honda parts from a Honda dealership, no issues $285 with shipping.
So here is the journey for those who wish to travel down this path. I downloaded the instructions by typing in the OEM part number into google, checked compatibility, got 2017 guide for 2016, close enough.
Read instructions over and over until I realized it is simply inserting an extra harness into the existing harness using male/female connector pairs to "splice" into existing branches.
I installed the antenna last, because I did not know the length of cable needed, and it would have been totally in the way.
The plastics come off like a dirty shirt, Honda has made this thing to be quick to put together, but nicely and well thought out. I used to work on 90s VWs and forget about it.
There are two harnesses, one for the heavy power stuff and the module, and a smaller one for the steering column connections. No idea why it needs to be there for the windshield wiper/washer stalk, but hey, you gotta love it. The small harness connects to the big one.
The module connects via a bracket up the steering column, way UP there with a 10mm nut. You have to plug in the large harness module connector before attaching bracket, as the bracket captures the connector.
The module gets attached first, then undo the fuse box, unplug, plug in male harness, plug male original into female harness connector. There is your heavy lifting right there, plug in, wire tie, glue on foam tape...
Release head liner, stuff wire under, glue antenna to windshield, route through, plug in...
Reconnect battery, everything is fuckered, car does not want to start, so out of desperation I crank needlessly until the electronics make friends. Car starts, stereo is angry wants to connect to GPS, seeking its father who orbits in heaven. Errors for lane departure, collision mitigation, brakes, everything is reporting failed.
Expensive dealer trip is now imminent, but wait. Infotainment, goes to home screen, car reports "Systems initializing, drive carefully" so I drive around the block, and all is well. Emotionally drained, I wire tie, put back plastic, go grab a hot cup of tea. Now I try the fob, lock and unlock work, panic works, engine start, no go. Press engine button, then lock on remote comes up NOREG. Yey... So for those who dare to install, I've just finished, will get it registered ASAP, so far so good. I will try to get some keys programmed if they are reasonable as well...
