planedoc
5W-40and was the Amsoil in your low temp Deisel 0/20? if not what?
Probably what cummins called for in the engine no?!5W-40
Even the valve cover gasket looks so fresh!! AMSOIL ftwYou are exactly
You are right about Mobil1 not being a PAO (polyalphaolephin) true pure synthetic. But, their extended life series (15000 mile) oil is. GF-5 even. And I'm an Amsoil dealer and believer/devotee. Amsoil SS (signature series) their best, is still a GF-4 oil. Yet, still seems to win every independent lab test out there. I use it in every thing I own. This is a pic of what the inside of my cummins diesel looked like at 140,000 miles. No sludge at all, it still looked like a brand new engine inside. It used 0 oil between changes, and I used it to pull a 10,000 pound trailer running 41 PSI of turboboost. That's what Amsoil can do with regular changes.
No, they specified 15W-40, but, permitted 5W-40 IF, it was a pure synthetic. Amsoil made both, but since the warm viscosity was the same, I chose the 5W for the superior cold flow.Probably what cummins called for in the engine no?!
And there is nothing wrong with using a lighter oil on cold start conditions, that's what smart people do lol. Good stuff. I gotta find some SS for my next change, I miss that gold.No, they specified 15W-40, but, permitted 5W-40 IF, it was a pure synthetic. Amsoil made both, but since the warm viscosity was the same, I chose the 5W for the superior cold flow.
The valve cover gasket was original, and didn't leak a drop. I just kept reusing it every time I pulled the valve cover off to adjust the valves.Even the valve cover gasket looks so fresh!! AMSOIL ftw
I chose the Mobil1 advanced fuel economy full synthetic for the 1st change around 7500 miles I had 30â„… on the minder.For sure man, I hear you. I just never over fill it, which would also be very bad for wot pulls. What oil are you running boss?
Nothing wrong with that choice. That is also the (good) Mobil1I chose the Mobil1 advanced fuel economy full synthetic for the 1st change around 7500 miles I had 30â„… on the minder.
What year highlander? I have a 20155/40 is in my Toyota Highlander 12/365, 90k and not a drop burns in 15k.
It's because we know these specifications are often decided by bureaucratic regulators who don't care one whit about the life and health of our expensive engines. They specify oils too thin to properly lube and protect our engines in order to save 1/10 mpg. If we had any trust at all in them we might follow their recommendations.... but we don't!It still amazes me, how anyone would consider an oil, outside that recommended by the manufacturer of the engine, to somehow be an upgrade ! Really ?! Have you consulted Honda on this ?
As somebody who is on the other side of the wall, I can tell you that is only partly true. Yes, there are lots of stipulations that have to be met due to regulations and mandated goals. No, they do not drive every decision that is made in regards to longevity of components.It's because we know these specifications are often decided by bureaucratic regulators who don't care one whit about the life and health of our expensive engines. They specify oils too thin to properly lube and protect our engines in order to save 1/10 mpg. If we had any trust at all in them we might follow their recommendations.... but we don't!
Look at motors from today vs motors 5, 10, and 20 years ago. We have 1.5L 4 cylinder motors producing more power than a C4 Corvette LT1 and over triple the MPG the LT1 made. The new 2.0 turbo motor from GM in Cadillac's is absolutely amazing. This is all due to regulations and companies competing with each other.
You would not believe the amount of computer testing and physical validation that goes into these decisions. If Honda is saying to use 0w20, it's because of tolerances inside the engine, not because Obama says to use 0w20 or you can't sell here.[/QUOTE
I believe engineers do the best they can to produce the highest quality products possible within the parameters they are given to work with. Some of these parameters come from government regulations that do not have our best interests at heart. Some come from the bean counters that also do not have our best interests at heart. Given these limitations, it really is amazing how good modern engines have become.
