It's time again for an oil change and another Oil Analysis- Done and UPLOADED
  1. amirza786
    amirza786 Senior Member
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    2006 Camry SE V6, 2013 Toyota Sienna LE, 2018 Honda Civic Si (SOLD), 2010 Lexus IS 350 Sport
    #1 amirza786, Jul 12, 2019
    It's that time again...7K and 20 percent left on the MM for an oil change and another oil analysis. I wanted to let the MM go down to 10 percent and eek out 8 or 9K, but unfortunately I have a trip to SoCal next week and because of the extreme speeds and conditions I will be putting the car thru, plus the fact that I don't know when I will have a chance next to service her, I decided to get it changed today and collect an oil sample.
    I am really curious about the condition of the oil on this change interval, as between February and now I really put a lot of miles and stress on the engine, much more than from my last oil change. I had to make several trips between Northern and Southern California, plus I had to do a ton of stop and go driving in LA traffic (driving in LA traffic for 1 week alone made the MM go down 10 percent!).
    So these are the questions I am hoping to answer:
    How well did the engine oil hold up after 7K of extreme driving conditions
    How much more mileage could I have gotten out the current oil
    How much did it break down
    Fuel dilution and engine wear metals
    Does the current oil I am using sufficiently protect my engine
    The current oil I am using is Idemitsu 0W20 ZEPRO. I will be sending my sample this time to Blackstone labs
    ***EDIT***
    The oil analysis has been uploaded, you can find it in one of the later posts
    Mocha90210 and SouthSideBeef thanked this.
  2. silverblip
    silverblip Senior Member
    May 30, 2019
    454
    431
    Occupation:
    Machinist
    Newport News VA
    Dan
    2019 LSM Civic Si Sedan
  3. saiko21
    saiko21 Senior Member
    Feb 16, 2019
    346
    148
    Occupation:
    Trust me I am an Engineer!
    Sacramento
    Sai
    2019 Civic Si Sedan, 2005 Toyota Corolla (Sold)
    :popcorn::headbang:
    FLOPPER thanked this.
  4. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    Today I received my oil analysis from Blackstone Labs. I want to again state that the oil sent in had 7K of extremely hard driving. Everything looks great, oil dilution is 100 percent not an issue with my car. Also for those who have concerns using 0W20 in this engine, have no fears. They also suggest I go 8K before my next oil change. PLEASE NOTE: they got my mileage wrong (it should have been 7,600), I have emailed them to correct this on the report
    Jay19Si, Mocha90210, blackie X and 4 others thanked this.
  5. Syntek
    Syntek Senior Member
    Jan 18, 2016
    648
    358
    Occupation:
    Networking Engineer
    Los Angeles, CA
    Brian
    2019 PWP Civic Si Sedan
    Did you have rev-hang disabled or enabled during these 7k?
    amirza786 thanked this.
  6. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    Rev hang is enabled. I hate it disabled, it causes the rpm's to drop to fast between shifts causing a slight jolt
    ne0guri thanked this.
  7. ne0guri
    ne0guri Senior Member
    May 22, 2017
    782
    767
    Mars
    2017 White Orchid Pearl Civic Si Sedan
    Interesting... I don’t feel the jolt when upshifting but I feel it when I’m in boost range cruising and then let off gas. The car will lurch and jolt for a second and if I blip the gas again and let go, it will do it again.
  8. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    I prefer rev hang, I got so used to it that it doesn't bother me at all. I really hated driving when it was disabled
    Honda_RacerX and ne0guri thanked this.
  9. Syntek
    Jan 18, 2016
    648
    358
    Occupation:
    Networking Engineer
    Los Angeles, CA
    Brian
    I feel this. I was debating turning it back on since I also got use to it. I feel it's perfect when shifting between 2500-3000 anything above 2nd gear with rev-hang disabled
    Honda_RacerX thanked this.
  10. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    Another benefit of having rev hang enabled is that you don't get oil blow back when you release the accelerator. When releasing the accelerator, it causes a vacuum in the engine sucking unburnt oil and fumes into the exhaust. Rev hang prevents this
    ne0guri and Syntek thanked this.
  11. Syntek
    Jan 18, 2016
    648
    358
    Occupation:
    Networking Engineer
    Los Angeles, CA
    Brian
    I have a catch can already for this but if it'll prevent it more then I'll deal with it and re-enable
  12. ne0guri
    May 22, 2017
    782
    767
    Mars
    Do you think this can affect fuel trims? I'm having wide fluctuations on my fuel trims and my STFT jumps all over the place from -20% to 18%. The fluctuations also seem to happen when I blip the accelerator within boost range.
  13. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    I am unfortunately not knowledgeable enough to answer that. Maybe @charleswrivers can weigh in
    charleswrivers thanked this.
  14. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    2,834
    3,024
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    Ha! Nope. Fuel trims are not my thing. Thanks for the vote of confidence though. There's definitely a few guys on here that have done datalogs and tweaked basemaps to dial them in as they desired though. Hopefully someone will chime in shortly.
  15. OP
    amirza786
    Oct 4, 2018
    3,113
    2,987
    Occupation:
    Director of IT
    A
    Your welcome. Thought I would give it a try!
