Is this a boost or exhaust leak sound?
  1. Tomyabo225
    Tomyabo225 Member
    May 8, 2019
    Elgin IL
    Tom
    2016 EXT
    Does this sound like a boost or exhaust leak? Heard this for the first time when I pulled I to a parking garage.
    Sound starts as I give it gas and then fades away a couple of seconds after I let off.
  2. glossyprimerX
    glossyprimerX Senior Member
    Apr 13, 2017
    127
    41
    Occupation:
    Asset Management
    AZ
    2017 Sport Hatch MT Sonic Gray
    Check your air box lid and intake piping. All pressurized air is metered through your MAF sensor. The ecu usually picks up on a leak and you should be able to review your fuel trims and compare them to other cars to see if they are off. I would think that a code would be thrown if you had a boost leak but maybe others on here can speak from experience.
  3. parshisa
    parshisa Senior Member
    Jan 11, 2017
    647
    266
    Texas
    Civic X Hatchback LX
    Looks like it makes two of us. The only difference is that the sound is pronounced over 2k and with the car driven in 95-100 deg heat for half and hour or so (really hot engine). Also, i’ve been driving like that for over 2k now. Same mpg, same car performance (so it seems). 40K on clock, no tune. What’s your mileage?
  4. TrippyPancakes
    TrippyPancakes Senior Member
    Jul 23, 2018
    75
    2018 Civic Sport (CVT)
    I have a similar noise when accelerating. I'm at 20k miles with a tune. I noticed the sound become more pronounced after I changed my air filter but as far as I can tell no leaks in my piping. What filters are you two using?
  5. parshisa
    Jan 11, 2017
    647
    266
    Texas
    Funny that you mentioned air filter, i had mine changed around 5k ago and that’s when i started noticing it. I’m using honda oem filter
  6. SDAlexander8
    SDAlexander8 Senior Member
    Jul 11, 2019
    649
    445
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    Turn car off, Open your hood, pull the tabs back on the air filter cover, lift the cover up and check the filter to make sure that its even there and that it is clean. I promise it’s not scary.
    It’s 4 screws for the 1.5T, but the 2.0 it’s 2 metal spring clips. No tools required
  7. parshisa
    Jan 11, 2017
    647
    266
    Texas
    Thanks for the heads up. Although i’m quite certain it has been installed properly. Cuz i did. Same way i’ve done it in the past. Many many times
  8. SDAlexander8
    Jul 11, 2019
    649
    445
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    My other suggestion would be to just look around the engine and make sure all hose connections are good. If so then I’d take it to the dealer to find out what it is.
  9. parshisa
    Jan 11, 2017
    647
    266
    Texas
    All hoses are tight and no loose connections. True, dealer would be the way to go although i’ve been this route before, until it shits the bed they will act like there’s nothing wrong. Have 0 desire waisting time dealing with those crooks. Will drive till it breaks and then address, plenty of warranty still left
  10. SDAlexander8
    Jul 11, 2019
    649
    445
    Occupation:
    Environmental
    Indianapolis, IN
    Steve
    2017 Civic Si Coupe
    Experiencing any power loss or driveability issues?
  11. parshisa
    Jan 11, 2017
    647
    266
    Texas
    no, nothing at all. feels the same. obviously, the car is a bit sluggish as it always is during the summer heat. still delvers 37mpg with mixed driving.
  12. OP
    Tomyabo225
    Tomyabo225 Member
    May 8, 2019
    Elgin IL
    Tom
    2016 EXT
    You have the same sound!? Nobody was responding so I thought I was alone.
    30k no mods.
  13. parshisa
    Jan 11, 2017
    647
    266
    Texas
    No, nothing at all.
    it sounds similar, yes. have no clue what it is. I'm waiting for the temps to cool down in texas and see what happens. drive it till she breaks essentially
  14. OP
    Tomyabo225
    Tomyabo225 Member
    May 8, 2019
    Elgin IL
    Tom
    2016 EXT
    I've noticed that mine more noticeably happens when it's hot out. What if something expands when it's hot, making the sound?
  15. parshisa
    Jan 11, 2017
    647
    266
    Texas
    Same here. No sounds with ambient temps below 90. Once above and some highway driving, it comes back. No clue what it is and won’t make a move till something breaks
