Is my motor fucked?
  1. jamesbond4678
    jamesbond4678 New Member
    Sep 2, 2019
    Blake
    16 civic ex-t
    Ok, first post so dont murder me for formatting stuff. I am the proud owner of a 16 civic coupe EX-T. I love this little car to death and have been driving it for about 8 months now. Recently I bought a ktuner 1.2 and put it on the 21 lbs boost base tune it comes with and messed with a few of the quick select options. Love it and it's a completely differnt car. Last summer I took out all the exaust up to the down pipe and have been running it open for several months now with no problems. These two did not conflict with each other. Yesterday I changed the spark plugs on the car and had no issues running it, it no longer ran rough while at a stop in drive. This morning I get up to go get breakfeast and when under hard acceleration the exaust pops rythmicly. It gets more intense and jerks the higher I rev. I have no idea what the issue is but I'm going to go make sure the spark plugs are in correctly, what can I do to fix this or did I fuck my car? Please help.
  2. charleswrivers
    charleswrivers Senior Member
    Nov 3, 2017
    2,910
    3,152
    Occupation:
    EMNCS(SS)
    Kingsland, GA
    Charles
    '14 Odyssey EX-L '18 Civic SI Sedan '94 300zx twin turbo 2001 Ford F-150 Sport
    Everything was fine.
    You changed your plugs.
    Then they were not fine.
    Pull and read your plugs. Verify they were the proper plugs in the first place and gapped properly. Post pictures of them on here if you’d like. Plan on buying replacement OEM plugs and reinstalling at a minimum... or reinstalling your old plugs if they’re still on hand. Eliminate the variable.
    I can’t advise further until you undo the last thing you did that made the car run badly and not knowing whether you used the proper plugs... gapped and installed properly. It is, however, the smoking gun.
  3. latole
    latole Civic Lx 2018 Manual , Civic LX 2016 Manual
    Apr 13, 2017
    2,041
    456
    Vaudreuil,Quebec ,Canada
    :thumbsup:
  4. PowerPerLiter
    PowerPerLiter Specific Output
    Jun 6, 2018
    1,278
    1,084
    Midwest
    He did state "it no longer ran rough while at a stop in drive"
    Sounds like there was an issue which prompted the plug change.
    Agreed with double checking your work but if there isnt any issue with the plugs or install of the plugs, then you will be looking at other issues...
    MaxPower thanked this.
  5. stevessvt
    stevessvt Senior Member
    Oct 2, 2018
    82
    83
    Lake Worth
    Steve
    2020 Modern Steel Metallic Civic Si
    Spark blow out?
  6. Hollywoo0220
    Hollywoo0220 Customer Service oriented (most of the time) :-)
    Feb 10, 2019
    647
    437
    WA
    RJ
    Tank, Lunar Module, and 1990 Diahatsu Charade
    With the delete of the entire exhaust system back to the DP you could have many issues that we cannot diagnose with the description. The exhaust stream is/was interupted and you are obtaining less velocity from it. You won't breathe as well for one and the turbo is working much harder. The heat alone could be radiant enough to have scored through a sensitive wire in the engine bay.
    It nice to be "COOL", but hopefully you learn your lesson from this (or not).
  7. UnknownCTR
    UnknownCTR Senior Member
    Jun 8, 2017
    430
    258
    2018 Civic HB Sport
    Throwing any CEL's? Seems it would.
  8. MaxPower
    MaxPower Senior Member
    Mar 2, 2017
    130
    152
    NJ, USA
    2020 Civic Si sedan ABM, 2017 CR-V EX, formerly 2005 Saab 9-2x, 1986 Prelude Si
    The approach described by @charleswrivers is absolutely the right one. The plugs are likely the culprit. Occam's razor. However, if not that...
    This jumped out at me too.
    OP - you said:
    But you also said:
    So - was it running poorly before you changed the plugs? What prompted you to change them?
  9. Pbergmann
    Pbergmann Member
    Jun 23, 2019
    Arizona
    Pete
    2019 Civic sedan EX-L
    Why not return it to stock, then see how it runs.
  10. joshhjackson2112
    joshhjackson2112 Senior Member
    Jul 3, 2018
    689
    411
    Raleigh, North Carolina
    Josh
    18' SI
    Am I reading this correctly? You ran your car for months without an exhaust? Not even the front pipe? Just blowing straight out the down pipe? Geeze. How could you possibly stand that for that long? Start with the spark plugs like Charles said but also put your fucking exhaust system back on. Delete your muffle / resonator if your trying to be loud and proud. Good luck and keep us posted.
  11. stevessvt
    Oct 2, 2018
    82
    83
    Lake Worth
    Steve
    You know what? This guy has 1 post to his name. I think he’s trolling us.
    Civics4Ever thanked this.
  12. pandai
    pandai Member
    Oct 8, 2018
    New Zealand
    Andy
    2018 Honda Civic Hatchback 1.8L R18 CVT
    It was probably running rough because, without the exhaust, there of a lack of exhaust backpressure.
    I also wonder if it now has a misfire?
  13. latole
    Apr 13, 2017
    2,041
    456
    I agree.
  14. FC3L15B7
    FC3L15B7 I'm a machine.
    Nov 22, 2019
    342
    193
    Occupation:
    Truck Driver, because Badass is not an occupation.
    Daniel
    2020 Honda Civic 2 Door Coupe Si / 1993 Chrysler Intrepid 3.5L
    #14 FC3L15B7, Mar 27, 2020 at 8:43 AM
    I can't tell if you're being completely helpful or facetious. :D But I can say it's a good place to start. Plug gaps may be altered when the parts person or stock kid in the store drops them on the ground.
    Hey look, that plug gap is no longer what it's supposed to be. Lesson should really be, always inspect the plug gaps, regardless of pre-gapped plugs. ;)
    Great plug, Charles.
  15. latole
    Apr 13, 2017
    2,041
    456
    You are right. I alway check plugs gap before, so easy to do and may save some headeache .
