I tell you, if you know how to work a laptop (basic stuff) and can plug something into the bottom of your dashboard, you can install a tune yourself in about 15-20 minutes. It's super simple. Also, it's a set it and forget procedure and you will not be messing with anything once it's done. Simply tune and enjoy.Like I said, I would love to delete the rev-hang as well as a few more HP. However, I myself am not a DIY person, I would not want to mess with ECU settings without fully understanding the parameters and their impacts.
I used to do my own oil changes in my younger days. In Toronto, Honda oil changes are not too expensive. They charge $65CAN for an oil change while the cost for Honda oil and filter alone would cost $56CAN.
I know Honda OE oil is not the best but since I usually change oil at MM=30% left, any 0w20 oil would work.
I just tend to mod anything I own honestly.
I think this is a fresh take. Though I have many mods in mind, I haven’t done any yet partially because the car is fantastic as it is from Honda.In my opinion? No. I've got a ktuner, used it for a month then removed it because I felt it threw off the balance of the car (along with annihilating my mpg). Bone stock, it's quick with great handling. Once one thing is upgraded more cash will need to be applied to keep it in balance. All I've done thus far since the ktuner is throw in an intake for a bit more noise and performance. I realize I'm in the minority but if I wanted the torque and MPG drop a tune provides, I'd have bought a more powerful car to begin with. Just my opinion, YMMV.
What are you waiting for? The tunes that come with KTuner and Hondata are safe and conservative and will do exactly what you want. KTuner will give you a bit more in the way of quick and easy adjustments to "fine tune" your setup. No other mod needed for what you want to do. It's the best $500 or so you can spend on your car IMO.I'd just like a little more power so the car can be complete and where it should be. Already has very good handling @.97G. A mild tune to make the car more drivable would be great. Clean up the power band, delete the annoying rev hang and possibly add a pound or two of boost in sport mode. It's a daily driver and I'm not looking to go crazy or make the thing loud.
Will the "conservative" tunes decrease long-term reliability?What are you waiting for? The tunes that come with KTuner and Hondata are safe and conservative and will do exactly what you want. KTuner will give you a bit more in the way of quick and easy adjustments to "fine tune" your setup. No other mod needed for what you want to do. It's the best $500 or so you can spend on your car IMO.
No one can predict that 100%. But the question is, does that mean 175,000 versus, say, 200,000+ miles? I waited about 10 months to tune and have been tuned with both Hondata and KTuner base tunes (and now TSP Stage 1) for a year and a half. The difference in driveability is astounding.Will the "conservative" tunes decrease long-term reliability?
Depends how you drive the car. If you beat on it and never check datalogs or perform oil analysis or any preventative maintenance.....Will the "conservative" tunes decrease long-term reliability?
What year, model, and trim was your "old Z"? If you take an NA engine and convert to FI, most do not last. If you take an FI engine and add additional boost without properly tuning, most do not last. In either situation, "a little extra boost" can easily lead to leaning out which is a surefire way to damage an engine.I'm trying to get well informed on the car before making any changes to the tune. From past experience, you have to be careful playing with boost. I blew up my old Z running a few extra pounds of boost. The entire neighborhood would be filled with smoke from just turning the car on for 30 seconds lolz
