Interior Rattling at 3500-4000RPM
soapctr
David
2019 Honda Civic Type R
The rattling sound is coming from the infotainment screen area and every time I'm up at 3500-4000 RPM it rattles/vibrates.
I tried pushing down on all the edges but cannot find the source.
Anyone else experience this and got a fix?
jasonjm
Jason
Pennsylvania
Type-R
Best thing is to just start taking of panels and add foam, while also tying wires and taping them down where possible. This car is not a luxury vehicle, but that doesn’t mean you can’t apply the same type of panel foam.
sean465
London
Championship White Civic Type R FK8 R-03927
Yep, lots of us over here have this. One chap took it apart bit by bit and foamed up as much as possible and it worked.
Too much for me so I just turn the Remus and music up
soapctr
David
I might just take it in to the dealership while I get my oil changed. I'm used to interior rattling coming from an STi but this rattle is high pitched and really annoying to my ears
RosevilleSi
NorCal
2017 Championship White Civic Type R
I'm taking mine in this week. The buzzing and rattling is sooooo bad.
soapctr
David
Is yours like mine? where it just buzzes at a certain RPM? Let me know how it goes!
WrongWayWade
Gregg
Doraville, GA
I get a certain buzz from the engine into the driving compartment around 4400, gear doesn’t matter. Something harmonic going on. I doubt it can be ‘fixed’. I read somewhere that the CTR has really solid motor mounts so it’s no surprise that some engine vibrations are telegraphed though the whole car at certain rpms.
I don’t have ‘rattles’, just a bee-like buzzing from the engine. Ones in a long while some plastic pieces made some noise; it was from the center console where the side pieces meet the interior block.
handsoffsam
Sam
Houston, TX USA
www.trackjunkies.org
08 S2000 CR / 99 Spec Miata / 99 WRL Miata / 18 Type R
The rattles are on their way, I promise ;)
To OP: Just hit 11k on my 2018 R (my DD) and it's a symphony of buzzes, rattles and hums day to day. They come and go depending on temperature etc. Center console one week, seat bracket squeaks the next, and at random intervals each speaker front and rear (those little shits drive me mad the most). Every day is an adventure...but just like the S2000 had its quirks and sounded like a space capsule on earth atmosphere re-entry sometimes....the car makes up for it. But good luck taking it to the dealer, you'll be there every other week and by the time they're done it'll be worse than when you brought it in. Cheers.
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
I tend to get more buzzes and creaks in the winter time (when it goes below freezing). I've had a clicking clutch pedal for a little too long now. Honda said it was the CMC and replaced it... And that fixed it for about a couple weeks. Then it came back :/ Besides that the only other buzz/click I get sounds like it's coming somewhere in the steering mechanism, but only happens in the cold... Certain songs will also cause the door panels to rattle a little. Outside of that, I don't get much.
Type_RawR
Somewhere USA
2018 FK8 #14116 / 2008 FG2
Mine buzzes all the time, it is indeed rpm dependent coming in at 3.5k and fading out after 4k. It's definitely plastic and seems to be coming from the passenger dash or a-pillar area, i've already had it into the dealer for this problem and they were not able to figure out what is causing it. They removed the a-pillar covers and the center dash speaker and it was still present when revving the car off the ground on a lift so it isn't vibration from the road. I'm going to do a full motor mount swap so just dealing with it until I do that so I can figure it out from there as I assume it will only become more apparent after the mount swap.
tinyman392
Marcus
Illinois
I remember I had a rattle that sounded like it came in the direction of the passenger front wheel well. It ended up being something in my glove box (dealer plate covers vibrating against something).
hafadaze
Juan
Yigo, Guam
2017 Honda Civic Type R (#1106)
Truth. I've had rattles from week 1 and just decided to live with them. If you bring it to the dealer, there's a huge chance they'll F it up even more. lol
Gansan
Glen
San Diego, CA
1999 NSX, 2018 Civic Type R
The only two flaws that I feel are significant for my ownership experience have been:
1. OVERHEATING.
2. Buzzes and rattles, and squeaking seat.
I have felt around on the dash and instrument panel to try to find the sources, but so far the really annoying ones are all internal it seems like. Pressing on things mostly doesn't help.
handsoffsam
Sam
Houston, TX USA
1. OVERHEATING.
If you don't have a kazoo noise when shifting at high RPMs consider yourself lucky - that one reallllllly gets me...
