Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic
  1. vikz99
    vikz99 Senior Member
    Oct 18, 2016
    239
    73
    T.O
    2016 Civic EX, 2015 Honda Pilot EX-L, 2015 Nissan 370Z Nismo
    Is the Honda harness plugged into the correct connector at the fuse box location?
    nickjohn35 thanked this.
  2. vikz99
    Oct 18, 2016
    239
    73
    T.O
    Also make sure the bare wires from the wire spice arent touching each other.?
  3. nickjohn35
    nickjohn35 Senior Member
    Jul 9, 2018
    273
    208
    Occupation:
    Firefighter/Paramedic
    Cincinnati
    Nick
    Current: 2017 PMM Typer R. Former: 2004 350Z
    Yes. Double checked that.
  4. nickjohn35
    Jul 9, 2018
    273
    208
    Occupation:
    Cincinnati
    Nick
    I thought maybe it was my solder job was shitty so I disconnected and connected using posi-taps...
    still nothing. And I know the mirror works cause I tried it in my wife’s Murano and it worked.
  5. vikz99
    Oct 18, 2016
    239
    73
    T.O
    Ground on the connector?
    So swapping red didn't work?
    Wonder what type of harness you have..
  6. nickjohn35
    Jul 9, 2018
    273
    208
    Occupation:
    Cincinnati
    Nick
    I removed the appropriate grounding bolt and placed the grounding wire on there.
    I swapped the red with orange and now the mirror works but is on constantly. Homelink doesn’t work and car still doesn’t start...
  7. vikz99
    Oct 18, 2016
    239
    73
    T.O
    Is this what your Honda connector looks like?
  8. nickjohn35
    Jul 9, 2018
    273
    208
    Occupation:
    Cincinnati
    Nick
    No. It was black....
  9. vikz99
    Oct 18, 2016
    239
    73
    T.O
    thats your connector? why did you cut the wires off?
  10. tk_chatt
    tk_chatt Member
    May 8, 2016
    Chattanooga, TN
    Do you have a multimeter? The way you show your wiring in your post should be correct.
    If you do, check continuity from a ground point to the black wire. Once that’s confirmed, check 12 volts between the ground wire & ign, then between the ground wire & the reverse wire. Finally, check that you have constant 12 volts feeding the Homelink circuits.
    Once you’ve verified your harness, check the fuse box under your hood. Depending on your model, there are two 30 amp IGN fuses or one 30 amp & one 50 amp fuse.
    These feed the main power to the IGN relays. ( They’re listed in your Owners Manual )
  11. vikz99
    Oct 18, 2016
    239
    73
    T.O
    tk_chatt knows his thing on it. I would try what he said.
  12. nickjohn35
    Jul 9, 2018
    273
    208
    Occupation:
    Cincinnati
    Nick
    The mirror I have is a Gentex 453 requiring a 10 pin connector. The Honda harness (mine and yours) are 7 pin.
  13. vikz99
    Oct 18, 2016
    239
    73
    T.O
    follow tk_chatt.. he knows how to do it.
  14. tk_chatt
    tk_chatt Member
    May 8, 2016
    Chattanooga, TN
    If you have no power on either the reverse wire, or the ignition wire, check the 30 amp fuse A1-5 in your under hood fuse panel.
  15. nickjohn35
    Jul 9, 2018
    273
    208
    Occupation:
    Cincinnati
    Nick
    I do have a multimeter but a total absolute newb at them. I will definitely do my best and check what you said.
