Kit523
I got the home link and auto dim but no compassDepends on what your mirror does.
Does it have auto dimming? Homelink? Compass?
Sweet thanks !!This may assist..
i have installed my gntx 453 mirror it has auto dimming, homelink and compass with the exact pigtail harness in the pic.You should be fine.
This may assist..
Where are the stock harness located behind the dome light ?i have installed my gntx 453 mirror it has auto dimming, homelink and compass with the exact pigtail harness in the pic.
since the stock harness only had 3 wires - switched power - ground - and reverse power.
i didnt want the homelink on constant power so i connected the batt and ign wire together to the red wire on the honda harness, the ground to ground and the blue reverse wire to the white reverse + wire on the harness.
my question is how to program the homelink? I have press both outer homelink buttons for 20 secs until i see the rapid blink to clear the settings.
when i hold the homelink button down and the button on the chamberlain remote i never see the mirror homelink light flash, am i doing something wrong?
No I bought the Honda harness so it runs from the mirror to the headliner to down the A Piller post the wires run behind the air bag and to the inner fuse box behind the traction control button, it's just plug and play connector to fuse box all u have to do is screw in ground connection to frame or bodyWhere are the stock harness located behind the dome light ?
Do you have the part number for the harness ? I will order mine nowNo I bought the Honda harness so it runs from the mirror to the headliner to down the A Piller post the wires run behind the air bag and to the inner fuse box behind the traction control button, it's just plug and play connector to fuse box all u have to do is screw in ground connection to frame or body
08V03-TBA-100Do you have the part number for the harness ? I will order mine now
I ended up mounting mine today. Direct swap for the CTR. I tapped the ground (black) and switched 12v (red) at the map light then ran two wires down to the fuse panel. One is 12v constant and the other is for the reverse light (not wired yet). Works perfect! Thanks for the thread!
I was doing some little digging for this harness it seems like they have different harness if the mirror doesn't have the compass options ? Or they share the same wires ?08V03-TBA-100
The compass is powered on with auto dimming it doesn't have it's own power, only the homelink has its own powerI was doing some little digging for this harness it seems like they have different harness if the mirror doesn't have the compass options ? Or they share the same wires ?
Alright do you have a link where you get your wires ? It seems like they are all going for 60 bucksThe compass is powered on with auto dimming it doesn't have it's own power, only the homelink has its own power
https://www.google.com/search?q=08V...&ved=0ahUKEwiXjOGlhuXWAhUKySYKHZAECFgQgjYIyAIAlright do you have a link where you get your wires ? It seems like they are all going for 60 bucks
Did you ever get the homelink to work hooked up with both wires going to the red switched?i have installed my gntx 453 mirror it has auto dimming, homelink and compass with the exact pigtail harness in the pic.
