Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic
vikz99
T.O
2016 Civic EX, 2015 Honda Pilot EX-L, 2015 Nissan 370Z Nismo
it should be:
Pin 5 should be Reverse
Pin 6 - Ground and
Pin 7 - Ignition
nickjohn35
Nick
Cincinnati
Current: 2017 PMM Typer R. Former: 2004 350Z
it should be:
Pin 6 - Ground and
Pin 7 - Ignition
Based on this and the picture I provided this is exactly how I have the Honda wire harness connected to the 10 pin pigtail...
blinkz0rz
Jrod
Chicagoland
2018 FC1 Civic Si, 1997 Dodge Dakota, 1972 Plymouth Roadrunner 440, 2010 JKU Jeep Wrangler
Bumping this a bit, but I just picked up a Gentex GENK41A mirror and noticed it will take some work to fit on my Si. It has the wires coming out of the wedge and not exactly the 453 plug.
Honda Civic 10th gen Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic s-l1600
I'll follow the wiring diagrams and helpful advice from this thread. I'm an electrician by trade so I will see if I can get this setup to work.
I also ordered the OEM attachment, 08V03-TBA-100, so I imagine splicing that won't be bad as long as I can make sure the wires are properly marked.
Honda450r14
2019 Honda Civic SI sedan
I just installed a gentex series 8 auto dim with compass an homelink in a 2019 Civic si. I used the Honda oem harness that is for a mirror with homelink part number 08v03-tba-1a0 it plugs in an has keyed hot constant hot an ground...
eXstasy
SF Bay Area, CA
'19 CW CTR
I got Honda OEM Harness 08V03-TBA-1A0 but the plug does not match the Gentex Series 8 Auto Dim w/Compass and Homelink mirror (frameless). Can you tell me exactly which model you got?
The Honda harness is on the left, the Gentex plug is on the right
Honda Civic 10th gen Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic IMG_0751
Honda450r14
you got to wire it together I'll get you the three wires on the Honda harness you use and then the three on the mirror that you use... Just have to find all my wiring diagrams on it
eXstasy
SF Bay Area, CA
'19 CW CTR
Oh I see. That would be great, I'd appreciate it!
Honda450r14
This is the wiring diagram The color written in pen are the Honda harness colors...
Honda Civic 10th gen Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic IMG_20191219_220933
eXstasy
SF Bay Area, CA
'19 CW CTR
I managed to install everything. The wire colors on my Honda harness were different than you specified so I used a multimeter to find the ones I needed. The Posi-Taps pictured were temporary. After plugging things in to confirm they worked, I cut off the connector entirely and spliced the wires into the Gentex plug.
Gentex 50-GENK85A
Honda Harness 08V03-TBA-1A0, 14 pin connector, 5 wires: yellow, light gray, light green, black, purple
Light Green - Ground - Gentex Outside Black Wire w/ground loop
Yellow - Constant 12V - Gentex Middle Black Wire
Purple - Switched 12V (Ignition ON) - Gentex Outside Black/White Wire
Honda Civic 10th gen Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic IMG_0839
Honda Civic 10th gen Installing a Gentex auto-dimming mirror with HomeLink into a '16 Civic IMG_0988
Honda450r14
Gentex 50-GENK85A
Awesome description!!!s my colors were different that is strange I had all the same part numbers from Honda ...glad you got it figured out it's so nice the mirror is slick as heck
fenix-silver
Central PA
2019 Si
With the 08V03-TBA-1A0 harness has anyone figured out what the grey and black wires are for? I assume one might be the switched reverse wire? edit: nevermind. seems the Honda harness already disables the dimming while in reverse with just the 3 wires. still curious what the other 2 are for though...
double edit: so black wire on the Honda harness is definitely ground, NOT the light green wire. With light green wired up to ground, the mirror loses all power when in reverse. Not sure what the light green and grey wires are for then.
Honda450r14
Lt green is power in reverse
Gray is dash light illuminate ..I used neither of these.
Hlee
Harry Lee
2018 Civic si
Reverse wire tapped:
How did you know to tap the reverse wire from the Gentex 453 mirror to this location? That green wire from the car's harness, what does that control? Can that wire be location at the fusebox? I have a 2018 Civic si and trying to tap into the reverse as well. Are you sure tapping into this green wire will disable the auto dim when car is in reverse? Let me know.
[/QUOTE]
Trey
R-00621
Atlanta, GA
2017 CTR #00621
It’s in the factory wiring diagram.
Hlee
Harry Lee
2018 Civic si
Unfortunately, I do not have a Honda Civic factory wiring diagram my car so I cannot verify that and will have to take your word. Ok, on the wiring diagram (the green wire from that harness you tapped into) what exactly does that lead to or control? That's if you remember. Also, wouldn't it be wise to fuse (5A or 10A) that wire you tapped into the green wire on the harness?
