davemarco
- Jun 3, 2017
- 148
- 2,638
- 1,458
- SoCal
- 2019 Civic Type R (CBP), 2013 Audi TTRS
What kind of sound deadening did you put in, and under which panel? Looking to do something similar.I put it in last night along with solid shifter base bushings. In ALL honesty, it was worth the 35 bucks, but it's not a very big difference for an Si to the TypeR, and while I may need more time with it, it is probably at Most 10% shorter than the Si, it's really not that noticeable. I may still do the boomba transmission side weight and shortening. BTW, I used Sirimoto's youtube install as it was the best and easiest to follow. The whole process was very easy but time consuming and the hardest part was removing the cables from the base, I had unbolted prior and it took some effort, then the install same thing was the hardest was orienting the cables correctly and then getting them back in.
Changed the oil and filter, did the shifter base bushing swap and TypeR base/lever change and put some sound deadener on the center hump and total time was around 2 1/2 hours. None of it is hard, but it is time consuming, and for how much it cost right now it is definitely worth it for a standard/base civic owner, but I'm not so sure it is for the Si, at the 35 dollar price point - yes, but if it goes higher I would say no as a matter of opinion for those looking for this
