How would I add a wire into this ?
supreme604
Vancouver
2016 Civic
recently installed fog lights that use up the connector where the fuse box is located, butbI've got some foot well lights that also use that same connector.
Honda Civic 10th gen How would I add a wire into this ? QiakBGH
how would I go about putting a wire into that spot in the photo? or should I just wire them to a fuse
calonzo
New Haven, CT
2016 Honda Civic Touring
You can't add them to the connector, but you could splice the two wires together, assuming that a single wire is enough to handle the current of both sets of lights. If you are not sure, then wire them to a separate fuse.
jacobsjp03
New Mexico
2018 Civic Sport Touring Hatchback
If you can figure out the pin size or maybe a connector part number, you can buy pins and a crimping tool. Then crimp and pin the connector, something like this...
