How to remove this snap ring on center console?
biosses
Japan
How to remove the snap ring for the center console? i need to reuse the snap ring.
Honda Civic 10th gen How to remove this snap ring on center console? Untitled
Gruber
Mark
TN
Yo can just insert the right size screwdriver in the E-ring opposite its opening and pry it out. Or needle nose pliers in the same place and pry or pull. The most important is to not let it shoot somewhere so you can't find it....
latole
Vaudreuil,Quebec ,Canada
Honda Civic 10th gen How to remove this snap ring on center console? Capture d’écran, le 2020-03-26 à 04.20.06
with small screw driver in the left "hole. and push it to the left. Be careful to not loose it, it may be like a spring.
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
If you don't have a screwdriver handy you could also use a straight edge like a small ruler and push the clip from the open end side. Looks like it has enough meat to push it far enough to pop off or not to pop back into place.
biosses
Japan
Did you remove it ?
I found out i didn't need to remove to make the switch from cloth to leather center console armrest. I only need to make the switch between the top pieces of the consoles.
latole
:thumbsup:
