How to remove this snap ring on center console?
Gruber
Yo can just insert the right size screwdriver in the E-ring opposite its opening and pry it out. Or needle nose pliers in the same place and pry or pull. The most important is to not let it shoot somewhere so you can't find it....
latole
with small screw driver in the left "hole. and push it to the left. Be careful to not loose it, it may be like a spring.
Mikeybc
If you don't have a screwdriver handy you could also use a straight edge like a small ruler and push the clip from the open end side. Looks like it has enough meat to push it far enough to pop off or not to pop back into place.
