how to remove a-pillar trim
  1. staged84
    staged84 Senior Member
    Jan 13, 2016
    88
    NJ
    Civic touring
    I've been hearing rattle from driver side at low rpm. (around 1,500)
    It's either coming from driver's side a-pillar or vent on top of dash.
    I'd like to open it up myself and see what's going on.
    If you know how to remove the trim or have a guide let me know!
    Thanks!
  2. Pearl
    Pearl Senior Member
    Apr 15, 2016
    327
    356
    SWFL
    2016 CivicT
    At the very top of the A pillar is a little plate with "Side Curtain Airbag" spelled on it. That's actually a thin cover for a screw beneath it. Just stick a fine blade under its edge and pop it open to reveal the screw. Remove the screw and tug the upper part of the A pillar plastic with your fingers and it will easily give way. The bottom most part is hooked so just tilt the plastic down toward the steering wheel and it'll unhook.
    ddood, chewy, mokylim and 11 others thanked this.
  3. OP
    staged84
    Jan 13, 2016
    88
    NJ
    Civic touring
    Thx, i had no idea there was screw involved. I was about to just pry it open before making the thread lol. I'm glad i asked.
    Mmorales2 thanked this.
  4. Pearl
    Pearl Senior Member
    Apr 15, 2016
    327
    356
    SWFL
    2016 CivicT
    My pleasure. Please feel free to click the Thanks button so I can get a free sticker after reaching 1000.
    Donuyen18, grumpyguy6, Phylanx and 12 others thanked this.
  5. nboyanov
    nboyanov Senior Member
    Dec 29, 2015
    56
    Southern California
    2016 Civic EX-T
    Were you able to fix this? I have an annoying rattle coming from the driver side pillar too but I'm skeptical of opening with airbag stuff there. Thanks!
  6. cmanman
    cmanman Member
    Nov 1, 2016
    Parker
    2017 Civic Hatchback EX
    Don't know if its the same rattle, but I found my rattle to be the sun visor. When I unlatch my sun visor from the hook my rattle goes away.
    nboyanov thanked this.
  7. Henrychurchill10
    Henrychurchill10 New Member
    Nov 19, 2016
    massachusetts
    2017 Civic Hatch Sport
    I have the same issue with the a-pillar rattling at low RPMs. I'm going to the dealer to get an oil change and i'm gonna have them look at it while i'm there.
  8. jannapureddy
    jannapureddy New Member
    Oct 19, 2016
    2016 Honda Civic EXT
    Is your issue fixed please can you let me know even i have the same issue.
  9. shadow
    shadow Senior Member
    Jan 19, 2017
    78
    34
    Earth
    11 STI, 15 CRV, 16 Civic RS Turbo, 18 FK8
    #9 shadow, Feb 14, 2017
    I had some rattling coming from the a-pillar on uneven pavement. It stops when some pressure is applied to the pillar.
    I removed the pillar and applied some weather stripping / foam tape on the pillar's two tabs that go into the dash. So far so good.
    Removing the pillar is very easy. Use a small screwdriver to pop open the square cover that says SRS. It only overs a small bolt. Remove the bolt, pull down the rubber seal between the plastic a-pillar cover and the actual a-pillar. One clip mid-way down holds the a-pillar cover. Pull it gently. That's it.
    ddood, SSGCoxie, Gozen and 2 others thanked this.
  10. Gozen
    Gozen Member
    Jun 25, 2016
    Pennsylvania
    2016 Honda Civic Touring
    Thank you for this info.
    I am also wondering if @staged84, @nboyanov, or @Henrychurchill10 were able to figure out the cause of their noises, and if so, what was done to fix it.
    RBorden629 thanked this.
  11. Captain Falcon
    Captain Falcon Senior Member
    Mar 7, 2016
    64
    Northeast
    '16 Civic EX
    Guys, the dealership scratched my A-pillar cover while swapping out the inspection sticker. I'm thinking of buying and swapping the A-pillar piece out myself in order to avoid getting into a conflict with the dealer (I didn't witness the action, so I can't prove it). How should I proceed and do you think I'm doing the right thing?
