How to Change Oil on 2016+ Civic 1.5L Turbo
  1. Rocky5000100
    Rocky5000100 Member
    Nov 27, 2016
    47
    WI
    Civic Touring 2016
    #1 Rocky5000100, Nov 27, 2016
    Hi all,
    New to the forum. I didn't see a detailed how to change the oil, so I thought I'd post it up for those considering doing it themselves. It's pretty straightforward.
    This is my wife's car, and unfortunately the dealer didn't offer any oil changes at time of purchase.
    This will show how to change the oil and filter. I know the manual says oil only for this first one, but I like to change the filter with every single oil change.
    Tools needed:
    -Phillips
    -Flathead
    -17mm socket
    -Oil filter wrench
    Consumables needed:
    -0w20 Synthetic oil of your choice. I used Mobil Synthetic today.
    -Oil Filter. I used OEM filter, part number 15400-PLM-A01. I bought a 5 pack on Amazon which included washers. https://www.amazon.com/gp/product/B01ACAMV22/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
    -Drain plug washer
    1. Drive car onto ramps, and apply parking brake. I also place wheel blocks at the rear wheels just in case.
    2. Remove the silver underbody panel under the engine. There are 6 flat head 1/4 turn screws, and 2 phillips. Once removed, the panel slides towards the rear of the car and falls down.
    3. Remove the oil drain plug using the 17mm socket. It's on there pretty tight if it's the first time being removed, so careful not to gouge your hands. Allow oil to drain out.
    4. Remove oil filter. The oil filter was on there so tight, I had to go and buy an oil filter tool from the store ($5.99). The oil begins draining from the filter as soon as you loosen it, so have your catch can ready. Allow oil to drain.
    5. Install new oil filter. Rub a small amount of new oil around the seal before screwing on. The filters I use have a torque spec on them, but I just do them hand tight.
    6. Put new crush washer on drain bolt, and install drain bolt.
    7. Reinstall underbody panel. I found installing the two phillips first works best. Make sure the panel is in all 4 slots before tightening.
    8. Fill engine with oil. The fill hole is on the upper left hand side of the engine. Here I like to fill to just under, start the car, and drive it back to a level surface.
    Oil Capacity
    Without filter: 3.4 quarts
    With filter change: 3.7 quarts
    9. Allow car to run a minute or two, then shut off. Check oil level, and add more as needed. I usually check oil level a day or two after driving, just to make sure it's still good.
    Solus, Beaudixon2019, Shinjari and 40 others thanked this.
  2. PenguinMD
    PenguinMD Member
    Nov 1, 2016
    39
    Minneapolis
    2017 Civic Touring Sedan, CosBlu
    Do you have any strong opinions between the PLM-A01 vs PLM-A02 filters?
  3. bembol
    bembol SHIFT_
    Oct 12, 2016
    1,239
    623
    GTA
    Rafael
    17 FK7 Sport Touring, 15 Nissan Murano SL AWD
    I hate these Underbody Panels, it's a PITA but thanks OP for the write up.
    I don't mind DIY but ran into this BS when my sister bought her 2010 Acura TSX. The dealer charges $79.99 for Synthetic oil change so the difference was $25 to DIY and told her to take it to Acura instead.
    My Murano has this but being a Crossover it sits higher off the ground so it's easier to DIY and I use Castrol 0W-30 and not sure if they'll agree to use it.
    I will DIY, I just don't trust dealerships. Since I got into DIY the only time I set go back is for warranty work.
  4. OP
    Rocky5000100
    Rocky5000100 Member
    Nov 27, 2016
    47
    WI
    Civic Touring 2016
    No, I just picked the A01 based on what I read in this thread:
    http://www.civicx.com/threads/oil-filter-oem-vs-oem.4351/
    My main reason for going for OEM filter is that while this car is under warranty, I want no pushback from the dealer should any issue arise. I know they wouldn't be be able to prove anything if I used a Fram (for example) instead, but this way they'll see the OEM filter and not attribute any issues to that. For a few extra dollars per filter, I figured it was worth any potential headaches while under warranty. I'm still way under cost for what the dealer would charge for an oil change as it is.
    dark and GeoUSA thanked this.
  5. OP
    Rocky5000100
    Rocky5000100 Member
    Nov 27, 2016
    47
    WI
    Civic Touring 2016
    Yea, thankfully this one is easy to remove. I actually don't mind it, as it does protect the undercarraige from the salt, which is important up here in Wisconsin. While I had the panel off, I actually hit the parts of the frame that I could with Fluid Film. I've used it with great success on other cars, and other people's reviews are also positive.
  6. Truckin
    Truckin Senior Member
    Nov 10, 2016
    68
    NC
    2016 Honda Civic Touring
    I think you did a great job on this write up! :thumbsup:
    grecocivic, Rocky5000100 and Billy4202 thanked this.
  7. krav51
    krav51 Senior Member
    Feb 18, 2016
    57
    Philly
    2016 civic ex
    Can you give me the make and model ramps you used? Thanks
  8. Snoopyslr
    Snoopyslr Senior Member
    2,155
    Occupation:
    Engineering Technician
    This needs to be stickied. Fantastic write up. @timothyjay
  9. Design
    Design Senior Member
    Sep 28, 2015
    3,127
    2,701
    Southern California
    09 MS3, 17 ABM Si Sedan
    Great write-up. Any reason why you don't remove or lossen the fill cap first?
    Civics4Ever thanked this.
  10. Civics4Ever
    Civics4Ever Rally Red EXT
    Jul 31, 2016
    1,228
    977
    Occupation:
    Swimming pool tech
    Illinois
    Gene
    99 Civic DX, 16 EXT Civic Coupe
    This is great for anyone that doesn't know how. I always DIY oil changes and I had no problems.
  11. timothyjay
    timothyjay Senior Member
    Feb 11, 2016
    863
    722
    Occupation:
    Creative Director
    Jacksonville, FL
    Done!
    beanko and Civics4Ever thanked this.
  12. OP
    Rocky5000100
    Rocky5000100 Member
    Nov 27, 2016
    47
    WI
    Civic Touring 2016
    They're so old I can't recall!
    I usually do remove it, but I didn't this time. It does help it drain a little bit faster, but isn't absolutely necessary.
  13. IronFusion
    IronFusion Senior Member
    Nov 13, 2016
    490
    159
    Occupation:
    Software Developer
    Philadelphia, PA
    Fred
    2017 Civic Coupe EX-L
    Anyone know if there is enough clearance from the drain plug to the underbody panel to replace the drain plug bolt with a drain valve? I'd like to be able to do this, and attach a hose that runs directly into my can/pan and not drop any oil. I have an extractor too, which should make for faster drains.
  14. Sman
    Sman Senior Member
    Sep 9, 2016
    165
    65
    Wisconsin
    17 EX Hatch w/ Sensing
    I'm planning on getting one. Here is a thread about others using one
    http://www.civicx.com/threads/fumoto-valve-for-oil-drain-pan.6884/
  15. ArmyHokie
    ArmyHokie New Member
    Jan 2, 2017
    The Old Dominion
    2017 BNP Civic Sedan Touring; 2014 CBM Odyssey Elite
    Is there a torque spec for the drain bolt? A couple tips I've seen in the past:
    1. Drive a few miles first to warm up the oil so it flows out more easily. Just be careful of hot oil/parts underneath.
    2. Wear disposable rubber gloves. Have some rags or shop towels handy.
    3. Be prepared to move your oil catch pan as the flow changes.
    4. Wipe the drain plug surround and oil filter surround clean before replacing each to ensure no gasket/washer material remains.
    5. Recommend checking for leaks after adding oil and running the engine for a few minutes before reinstalling the under tray.
    6. Recycle your oil. Give a hoot, don't pollute.
