How to Adjust Front Camber on a Tenth Gen Civic
Wonkeymonk
Brian
10th gen civic sport hatchback
Does anyone have before and after photos of this?
L8apex
Southern Cali
2018 SGP Sport
Pulled these guide pins after installing Tein S-Tech springs, and they helped get my camber back within specifications. Interestingly, full negative on one side and full positive on the other got me in the spec window. Probably cause I shifted my lower subframe previously.
Also, if anyone is interested in an alternative to the Honda hole seals, I found these almost identical ones, but you in just have to buy 24 of them lol. Still not a bad price, select 1” diameter and matte.
https://www.ebay.com/itm/Color-Codi...-/173823770595?_trksid=p2349624.m46890.l49292
Honda Civic 10th gen How to Adjust Front Camber on a Tenth Gen Civic 2091B67D-A587-4AC2-ABC7-4DCD55776977
Honda Civic 10th gen How to Adjust Front Camber on a Tenth Gen Civic B8418068-EA2F-4E40-891E-0D50A3FAF9A1
nickname
Houston
'16 Civic Touring
What's the difference in ride quality with the springs?
And I'll pay for shipping if you want to donate 2 of those caps...
SuperSlowEk
Ryan
2018 Civic Sport Touring, 2000 Civic Hatch
Did you remove the guide pin while the strut assembly was still in the car ? I’ve tried with mine and can’t seem to get the nut to do anything it’s barely big enough to fit the nut alone
L8apex
Southern Cali
2018 SGP Sport
I removed the guide pin while I had the strut out. But it can be removed with the strut in the car. It’s not threaded, it’s splined. So turning it won’t thread it out like a bolt. But you will need to turn it a little bit to strip the splines. Then it pulls straight out. Or technically it pulls upwards.
GoldClass
Singapore
Civic Hatchback
So, the amount of the strut slide (after the guide pin removed) is not equate to the same measure of the camber move? I mean if let say the strut slide in 5mm after the guide pin removed, does the tyre also move in 5mm at the top?
