rohnin
- Iris
- Jul 16, 2018
- 9
- 76
- 20
- Los Angeles
- Honda Civic Type R
With the low profile tires do you have to fill up air all the time?
For manufacturer defects - yes. For basically anything else, no.Are the tires covered under warranty?
The Type R has TPMS sensors? You sure? The other gen X Civics use an indirect monitoring system that monitors the rotational speed of the wheels. If they don't match, the light comes on. There's no actual air pressure monitoring.The only times my TMPS sensor has gone off is with false positives, and in cooler climates too.
The Type R has a TPMS system that is indirect monitoring as you state. Honda calls it TPMS, because it IS a tire pressure monitoring system. Semantics, heh!The Type R has TPMS sensors? You sure? The other gen X Civics use an indirect monitoring system that monitors the rotational speed of the wheels. If they don't match, the light comes on. There's no actual air pressure monitoring.
I would think that it does. The civic manual is for the whole civic family, not just the Type R. It will designate the differences by saying "for the 2.0 L engine models only" if it was specific to the Type R. It has the way to do the tire calibration with "models with color audio system" as well as a section for "Models with driver information interface" and "Models with Display Audio." You should be able to find your version.Does the Honda civic touring 2018 has those tire sensor
Considering the Type R owner manual is the 5-door Hatchback manual, yeah all of them should have the same style of TPMS sensor. However, the manual also mentions the TPMS only exists on the US versions.I would think that it does. The civic manual is for the whole civic family, not just the Type R. It will designate the differences by saying "for the 2.0 L engine models only" if it was specific to the Type R. The only thing that might be different would be the PSI that you need to set the tires to since the Touring has a different set of wheels/tires.
