Think it does? I know it does. I posted a write up on here for DIY change on this car. Included links to the crush washers and torque specs, too. https://www.civicx.com/threads/transmission-fluid-change-2017-si.24076/#post-405131how many of you guys think the car actually shifts better with the OEM fluid?
do you have any experience with aftermarket trans fluids?Think it does? I know it does. I posted a write up on here for DYI change on this car. Included links to the crush washers and torque specs, too. https://www.civicx.com/threads/transmission-fluid-change-2017-si.24076/#post-405131
I went OEM because I was just trying to flush out the 'break in' fluid... the batch I put 11-5000 miles on. I wasn't expecting to feel a change but it is noticeable. That was a nice little treat.
A lot of people are going Amsoil and it wouldn't surprise me at all if it was the better fluid. But for my experience, even a OEM fluid swap is an upgrade.
Not anything compared to the other guys on civicx. The rest of my vehicles are old so picking up some Castrol ATF is about the extent of it. For what it is worth, I don't use Honda motor oil for the engine, I went Penz Platinum 0w-20. So it isn't like I am a 'OEM all the way' kinda guy. I just didn't feel comfortable swapping out of OEM so early in ownership. I'll probably do Amsoil for the next go-around.do you have any experience with aftermarket trans fluids?
when it co.es to motor oil... i dont think really anbody uses hondas oem oil. its probably just repackaged mobil1.Not anything compared to the other guys on civicx. The rest of my vehicles are old so picking up some Castrol ATF is about the extent of it. For what it is worth, I don't use Honda motor oil for the engine, I went Penz Platinum 0w-20. So it isn't like I am a 'OEM all the way' kinda guy.
i switched because the trans was notchy in 2nd and grinded once.I’m curious why you switched and what you’ve noticed since switching back. I was about to swap to Amsoil tomorrow!
I just did both today at 5k as well. Went to Amsoil Synchromesh as well.First oil change at 5k i changed the Tranny to Amsoil MTF.
