SC5000
- Feb 1, 2019
- 22
- 17
- SF Bay Area
- 2019 Civic Si
I have a 12inch sub and wanted a relatively easy/cheap solution to keep it fixed in the trunk.
I bought two brake pad spreaders for $8 each and then took a piece of plywood from an old dresser and cutout slots on each end so the spreaders can slide in from outside.
Then used the spreaders to clamp against the sub and trunk sheet metal as shown in the pictures. It doesnāt take a lot of clamping force to create enough friction to keep it in place. I also put some rubber patch on the clamping surface to prevent scratches.
Been running this for over six months and it works very well plus it is easy to remove.
One thing I want to mention is that the spreaders are very strong so one could deform the sheet metal in the trunk if tightened too much...which is what happened when I first tried it.
Now I try to position the spreader such that it is close to the vertical wall of the sheet metal where it is strongest.
Anyways, hopefully it helps someone out there looking for ideas.
