How do you open the housing 2019 FK8 Fog Light for Bulb replace?
Cayohuesojoe
Baltimore
'19 Honda Type-R
I opened the front grill (plenty of videos) I disconnected the bulb & now I cannot find a lick of info on accessing/replacing the Fog Light with Yellow LEDs. I wouldn't ask if I hadn't searched for what seems like a lifetime.
Thanks!
bluehatch17
bluehatch17
NJ
You are not going to be able to do it unless you replace the full unit (type r has less led standard).
(Jdm option full yellow over $400.).
Or Put some yellow film, which will eventually fade.
you can also open them up and change them out but most people won’t crack open a perfectly fine $150 part.
ExVTEC
Elliot
2019 CTR
I did the film, looks great. If it fades another 15bux will fix that.
Cayohuesojoe
Cayohuesojoe
Baltimore
'19 Honda Type-R
I figured it out after substantial reviewing online and a ton in this forum. Thank you. I have the Lamin-X on it now but it is a lighter shade than others so was attempting to change bulbs. All the directions online and here were great and I will be doing the grill removal to change horns over time but for now, sadly returning the bulbs as I'm with you, not in the mood to crack open a brand new set of lights. (Car only has 1,000 on it at this point)
